It is currently Sat Oct 31, 2026 8:50 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
Post Posted: Mon Oct 04, 2010 2:40 am
jaczook wrote:
I have a front ARB AIr locker with 22spline shafts, if I wanted chromo's can I fit the locker into a rear diff and install into the front?
Been thinking to but for a while but never got around. Since you guys are talking about it and the Aus dollar is good If it can be done then what a better time than this...
it wont work. you will need a rear arb locker. or if possable, i dont know if it is, get rear side gears installed into your front locker. but i dont know if this is possable
Post Posted: Mon Oct 04, 2010 2:44 am
appsie wrote:
just on this,would there be much use in going to cromos without any sort of locker?chances are unless your a boofhead the front wont break unlocked.or have you got a airlocker in the rear or something.
timmy runs 33s unlocked stock axles etc and i ran the same on 31s for 4 years with no breakages but have not long gone cromos as i wanted a front locker.
BUT as the boys have said a rear centre swapped straight in will be the go
This broke with a 560cc LJ50 motor in front of it unlocked:
Its an LJ shaft, but ultimately an LJ front shaft is the same as an SJ front shaft, just different length, and a different CV spline... Chromos are so blasted cheap, If your going to wheel hard stuff, why not? If you want to stay standard, you can start being like I am with the LJ, and start hoarding every axle shaft you can lay your mits on.... think I have about 8 or 9 good ones now, and I am still paranoid of running out :roll: :lol:
Clearance Hole Technology :P
Buy a 26 spline side gear kit from ARB and fit to the locker then put into a front or rear centre housing.
Post Posted: Mon Oct 04, 2010 2:51 am
Ben_Sierra wrote:
tanshi wrote:
i believe its aus, my last one was 1600, but i just made it in to seperate shipping orders
If customs notice you recieving multiple packages from the same sender at around the same time then they will treat it as a single shipment and charge duty and tax accordingly...
my father recieved one package, i recieved the other
Users browsing this forum: Google [Bot] and 442 guests
