It is currently Tue Nov 03, 2026 5:30 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
Vehicle: Jeep
Post Posted: Sun Jan 02, 2011 5:55 am
X 2
On the belt/belt tension...
Mine is actually squealing at the moment, until the belt gets hot...
Plus, and it may seem like a stupid question, do you have the temp controller all the way over in the Blue bit, if its not fully into the Blue bit, it will cycle on and off, thermostat controlled, so you get cycles of cold and warm air coming out, i set mine at the beginning of the blue bit, so it does cycle on and off, and doesnt sap the engine power so much...
Vehicle: Jeep
Post Posted: Sun Jan 02, 2011 6:15 am
89_tintop wrote:
monkey wrote:
Look in his rigs of auszookers thread it's said his vit has done 94,000km's i would have to say it's time to be regassed.
think of it thos way... do you regas your fridge at home?
the system is a sealed system amd shouldnt need to be gassed unless there is a leak.. regardkess of klms.. I have seen cars with 300000klms still on the factory gas
try checkimg the nelt adjustment.. and if that seems good then change the belt
Yes, but your fridge isnt bouncing/banging around and flexing and vibrating...
A/C was my trade, and i have never seen a perfectly sealed car aircon... they all leak, some more than others, and some very slowly... they have improved some things to reduce possible leakages, but they are still not a perfectly sealed system.....
Vehicle: LPG 1.6 Sierra
Post Posted: Sun Jan 02, 2011 10:13 am
I've gone through the Haynes manual and checked out what I can online, but still can't find what size/type A/C belt I need for a 90 Sierra.
Like Damo said, it'll be a lucky dip if Repco or the likes get it right... just wondering if anybody actually knows what size belt is needed for the job?
Post Posted: Sun Jan 02, 2011 10:15 am
take the belt into bursons-repco etc they should all have a belt sizer and be able to match one if it comes to that.
if the belt still has it the size is usually printed on it somewhere
Post Posted: Sun Jan 02, 2011 11:15 am
I have no belt to go off. There was no belt on the AC when I bought the car
Post Posted: Sun Jan 02, 2011 11:17 am
have a look to see if there is alisting for the belt on the suzistore website.
Post Posted: Sun Jan 02, 2011 11:37 am
I have a car here with factory AC...I'll have a look in the morning for you.
There is this one or this one
Post Posted: Sun Jan 02, 2011 11:18 pm
steak_knife wrote:
hutch wrote:
Also to add to Royce it could be an idler pulley that is siezing intermittently. Try squirting a tiny bit of wd40 or similar on the idler bearing (definitley not the belt) whilst the A/C is running.
I had a MQ Patrol with this problem and I tightened the belt but it still played up until the day the belt snapped and I then realized the Idler Pulley was siezed/rusted. :P
That wash's the grease out, may stop said noise if the is one, but if there isn't, you will shortly need to replace a seized idler..
Thats right... use the method I stated to "find" the problem... then rectify it. Sorry I made an assumption there but I guess "we" need to spell everything out for webwheelers. pompoms
255 characters
Users browsing this forum: No registered users and 437 guests
