It is currently Sat Aug 01, 2026 6:47 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
Vehicle: Sold zuk got a Bt50
Post Posted: Tue May 03, 2011 7:29 am
ok i might do it tomorrow dont want to annoy the neighbours and plus i cant really see that well also its too dark and cold and raining yeah i think thats enough excuses
Post Posted: Tue May 03, 2011 7:44 am
& your window's are to dark... :helloo:
Post Posted: Tue May 03, 2011 9:46 am
steak_knife wrote:
you should be able to pull most of the leave's out, trust me, you don't want to pull the dash out unless you have done one before.
you'll end up with million's of bit's....
So I guess I have to remove as much of the plastic trim vent thing under the windscreen as I can? How far down the firewall does the vent tubing go?
2002 SWB GV
Lifted and Locked
Post Posted: Tue May 03, 2011 10:11 am
Not to far from memory, just to the pollen.
yes to removing the trim's
have a look for rush while your in there, if leave's have been sitting for age's it possible she got some..
Post Posted: Sun May 08, 2011 3:38 am
After a bit of looking around I still can't find the source of the leak.
I laid some tissue paper in some spots to try to pin point if there was any moisture.
Here's the driver's footwell. The tissue at the front closest to the firewall is dry and was never wet. The rearmost tissue is quite damp. It sits over the rubber floor bung.
Passenger side firewall. I thought this may have been a source of the leak as on the other side of the bung is the felt liner on the inside of the cabin.
Passenger side showing where the water flows.
Drivers side firewall with the elec grommet. Thought maybe water might get in thru here but it was dry on the cabin side of the grommet.
Where water flows when wet.
Thought maybe water might flow from the rear door but this tissue was dry.
Could it be condensation coming in from the metal floor skin? The drivers floor bung looks secure but not 100% it's not coming thru from there. It is in the same spot as where the moisture is though.
Any ideas?
2002 SWB GV
Lifted and Locked
Post Posted: Sun May 08, 2011 8:22 am
Gaffer tape the bung & see what happens...
Users browsing this forum: Google [Bot] and 322 guests
