It is currently Sun Oct 25, 2026 2:08 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2
Post Posted: Sun Feb 12, 2012 1:37 am
thanks sogone!
well it's done!
the trayback is ready
took the first spin in the mud a few weeks ago and it and bad at all
place for the winchanchor and wafflebords
now it's time to make a fire and heat up the hotdogs!
Post Posted: Sun Feb 12, 2012 8:53 pm
looks good mate could you import and mot a LWB over there?
 Profile YIM
Post Posted: Mon Feb 13, 2012 6:52 am
sure you can
the big problem is that they are pretty rare around holland and the surrouding countries
germany an belgium
and importing one from australia or sealand is a bit expensive :wink:
there's occasionly a lwb chassis for sale, that might be a better option
Post Posted: Wed Oct 03, 2012 5:52 am
pics are always better then words
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Oct 03, 2012 9:13 pm
realy nice work mate , i love it
Post Posted: Thu Jan 03, 2013 7:20 am
don't seem like much
but i'ts 4 inch shorter
getting there slowly
Vehicle: Daisy
Post Posted: Thu Jan 03, 2013 8:43 am
You legend, that's exactly what I've been on about as far as vit transfer for duals in a Sierra! Are you still going to have to move the sierra transfer case back? I am yet to borrow a vit transfer to measure up.
Post Posted: Thu Jan 03, 2013 6:43 pm
I just chucked a vit transfer :roll:
Post Posted: Thu Jan 03, 2013 8:13 pm
I've got one here somewhere its a 2l one however
Post Posted: Fri Jan 04, 2013 2:39 am
throw in the engine aswell then
if I messered correct the sierra case is staying in it's own place
Vehicle: Daisy
Post Posted: Fri Jan 11, 2013 1:13 pm
Borrowed a transfer and pulled it apart, was wondering how you shortened it up whether you cut the front output section off and had to come back to check this thread, how have you sealed the front output up?
I'm wondering if it would be possible to re-make the middle part of the transfer case out of steel, it would only require the rear plate and a front ring for the bolts, to bolt to the front part of the transfer, maybe make the plates and case out of 6mm steel or so, would have to get everything lined up perfectly though when making it!
EDIT: Saw that you've cut the front output off, I'm also thinking the shaft will need to be cut down (going by the length of the jackshaft I have that goes from the box to transfer with transfer in standard position) which wouldn't be a problem since the bit to be cut off is only hanging out the end anyway.
I want to take the flange off the input of my sierra transfer to confirm the splines are all the same before I go too much further, just got to grab my mates socket set first!
Post Posted: Thu Jan 24, 2013 5:59 am
the axle needs to be shortened a view inch
i cut it of and then machined the inside so it could take the sierra case threaths and i don't have to cut a good sierra case
it's a matter of getting closer and closer and measer twice for everything
i think i pulled it apart and build it up about a thousend times :mrgreen:
but i'm getting to the end slowly now
some pics are missing but i had 3 rings machined out
1 for the bearing inside the case
2 for the coupler between the cases
3 for the seel of the axle
i'll try and find those pics back for ye
till then start drewling
Post Posted: Sat Feb 08, 2014 5:28 am
I sold the samurai last year and started a new project
an 1981 lj80v
its a bit crunchy but ill get there
It's been resting for 20years and the privius owners used to drive it on 4wd holidays in all off europe
so its seen more countrys then me
the brake were stuck
engine was dead
and it took a winch and creative thinking to get it in my shack
but that's all sorted out and now on to weld the body
Plans for it?
Spoa on sammy axles
32bfg mk2
1600carb engine
dualTcase
powersteering
exo cage
but thats for next year
i'll start with welding and driving nearly standard :peaceout:
Post Posted: Sat Feb 08, 2014 5:29 am
Post Posted: Mon Oct 20, 2014 2:41 am
It's been a while and not much has happend
the lj is ready and a two day testdrive in germany was real fun
Post Posted: Mon Oct 20, 2014 2:43 am
And i finaly got the last piece of the dualTcase back
so i can finish that project soon i hope
Post Posted: Thu Oct 23, 2014 8:07 pm
Users browsing this forum: No registered users and 101 guests
