It is currently Sat Nov 07, 2026 11:32 am
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2
Vehicle: Coily sierra..30" muds
Post Posted: Fri Jun 01, 2012 1:09 pm
Okay thanks mate, so did you just go the 40mm ebay kit and a 2" body or something or?
Post Posted: Fri Jun 01, 2012 1:48 pm
Exactly the same mate :peaceout:
Post Posted: Sat Jun 02, 2012 12:29 pm
Okay sweet as, thanks man. I think il just do body lift for now and spring when i have more $. Do you have to extend anything in order to achieve to inch body lift?
Post Posted: Sat Jun 02, 2012 2:17 pm
Nothing to extend as such. Remove the inner boot from the gearstick, loosen off the fuel filler hose.
Post Posted: Sat Jun 02, 2012 5:42 pm
No worrys. Thanks heaps for your help mate :D
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun Jun 03, 2012 4:58 pm
Woh hold up there is a locker that will apparently fit yer a jimmy is different yer but the part number for the front is apparently the same as a 98 jimmy ,I saw it on Herr like 2 years ago.if worst comes to worst deric at suzi sport sells A LSD center for like $400 ish. And king springs ,if u look on there site u can find out what coils u want they do make thicker springs for the Coily apparently ultima do the only extended shock so I would boy the front extended shocks,rear better quality shocks and the thicker coils go nice on the bumps off road those arms are week as plastic and jimmy arms do fit don't listen to any one says otherwise,u need them in pairs though . I have spare jimmy front arms if u ever need them .pm if ya do LOL
Green? greeeen is nice !
Post Posted: Sun Jun 03, 2012 6:22 pm
I think you are on LSD pompoms :rofl: No such thing as an LSD for a jimny or Sierra(maybe the early ones, and they are like rocking horse shit)
They would most likely be the phantom grip things. Steaming pile of shit in my opinion, stay way clear of them.
Post Posted: Sun Jun 03, 2012 8:35 pm
So are jimny arms stronger??
Post Posted: Mon Jun 04, 2012 8:07 am
Ring suzi sport at lawnton mate talk to Derek I had a Coily chassis so I looked a lot.all so I'm not sure if jimmy arms would be stronger they do have more clearence around the bushs were they mount wich looks like the might last longer but I don't know if they would be stronger
Post Posted: Mon Jun 04, 2012 8:34 am
Give suzi sport :rofl: at lawnton a call ,I'm not sure how good they are made .ROFLMAO
Vehicle: SJ80, SE416
Post Posted: Mon Jun 04, 2012 9:44 am
Jimny vs Coily control arms look identical except for 2 extra small tapped holes in the jimny ones. Bushes are identical. Only point of 'upgrading' would be to have newer oe rubber bushes fitted in the arms if your coily ones are split.
Post Posted: Mon Jun 04, 2012 9:47 am
You also have to do 'something' with the brake line which is mounted on the front passenger side inner guard. A brake shop extended my steel lines so they were neater than simply being bent and pulled through the hole. This is only a coily problem - not a problem on other Sierras.
Vehicle: 03 Jimny
Post Posted: Mon Jun 04, 2012 9:52 am
Jimny arms bend like a twig
Post Posted: Tue Jun 05, 2012 2:46 am
Reubs wrote:
Jimny vs Coily control arms look identical except for 2 extra small tapped holes in the jimny ones. Bushes are identical. Only point of 'upgrading' would be to have newer oe rubber bushes fitted in the arms if your coily ones are split..x2
Post Posted: Tue Jun 05, 2012 4:35 am
Hmm, where do you reckon i could get my hands on some decent/ strong arms?
Post Posted: Tue Jun 05, 2012 6:00 am
Off road armory or get them made,iv got good jimmy 1s but ad u can see from above there not realy an upgrade
Post Posted: Tue Jun 05, 2012 4:07 pm
Okay well, if there not really an upgrade theres no point. Mine are fine, il have a look at offroad armory
Post Posted: Tue Jun 05, 2012 4:31 pm
Zackary56 wrote:
I baught my sj80 last friday, since then iv rebuilt my carby, wacked a bullbar on it and just managed to fit a set of 30" muddies under it with minor grinding etc with out scrubbing. Im currently looking for some sort of kit to or a way to lift it/ give it more articulation. Whats your thought? Besides get a leaf sprung zook. Thanks
Why. They aren't that weak that you'll break one all the time... You'll break half a dozen CVs before bending a control arm to the point it is a problem. The trick is not to bounce and smash the arms onto rocks. If you are worried then just get a spare and pack it in the car. They are easily replaced on the side of a track. The arms are also much stronger then their diff and chassis mounts. At least the diff mounts should be beefed up before the arms - especially the rear ones if you plan to lift it and wheel it hard!
Post Posted: Tue Jun 05, 2012 8:06 pm
I got spares for ya pm me lol
Post Posted: Wed Jun 06, 2012 12:22 pm
Even patrol radius arms bend and snap all the time if they're punished.
If you wheel hard bring a spare. If not have a spare at home.
Stress less and go wheeling.
Users browsing this forum: Google [Bot] and 45 guests
