It is currently Tue Jul 28, 2026 11:07 am
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3
Vehicle: LWB Sierra & XL7
Post Posted: Thu May 27, 2010 7:49 am
OK well, time to keep the ball rolling..
I'm too poor to go ahead with diff locks, So the standard diff has found it's way into the steel carrier.
Almost ready to be installed on the weekend. :D
'92 Vitara & Camper trailer
Post Posted: Thu May 27, 2010 7:52 am
hey mate, did you swap over those rotisserie phone dialer looking things behind the sidegears or do they work for either gearset?
The LWB From 1993. Poetry in motion :P
Post Posted: Thu May 27, 2010 8:03 am
Hey Red is the mount on that diff the same as the one in that pic above????i can't quite tell from your pics :?
Post Posted: Thu May 27, 2010 8:04 am
I left it for the diff dude to sort out, But they look identical..
Here are the left overs.
Hang on a tic..
The R&P from the alloy carrier should be in the steel carrier.. which is what I asked for.. They should be the same right?
Post Posted: Thu May 27, 2010 8:06 am
yeah i was wondering why they would put the GV pinion into the alloy housing
Post Posted: Thu May 27, 2010 8:09 am
no the ring and pinion are not the same. the one from your vitara will be a 5.12 where as the one from the GV is a 4.3. Count the teeth on the ring that is left over. my count is 43 which would make that the GV ring.
Post Posted: Thu May 27, 2010 8:11 am
I think so, but yours has a bracket with a bush on it as well, not sure if that's just been taken off this one or it din't have it. Gus id say something about that in the FS thread. Sorry bout the hijack here buzzy, joe's about to do the same thing so just trying to sort everything out beforehand.
P.S. That photo of when you pulled apart your alloy one cracks me up every time. Do a little bit of mudbogging? :D
EDIT: fixed :)
Post Posted: Thu May 27, 2010 8:16 am
EDIT: fixed :)
But has it got the little stumpy bit with the two bolt holes in the same spot?????
Post Posted: Thu May 27, 2010 8:24 am
EDIT: fixed :)
Just went and had a look - short answer is no. it has a stumpy bit but it's not rounded and has no holes. good or bad?
Post Posted: Thu May 27, 2010 8:27 am
redzook91 wrote:
EDIT: fixed :)
Im pretty sure its bad :evil: HEY GUS we need your help!!!!!
Post Posted: Thu May 27, 2010 8:35 am
yeah it's sort of bad...
Vehicle: jimny
Post Posted: Thu May 27, 2010 8:38 am
dave whats the go, did joe do the work for you? is it done right??
Post Posted: Thu May 27, 2010 8:44 am
this is getting confusing... Redzook & Joe can you got back to the forsale thread??
Post Posted: Thu May 27, 2010 9:38 am
Sorry for the thread hijack Buzbox :wink:
Post Posted: Thu May 27, 2010 9:39 am
Yeah I picked it up off Joe this arvo on my break, I didn't have time to check it out properly..
I think I'll have to take it back.
Post Posted: Thu May 27, 2010 9:42 am
The same thing happened to Stuey
Post Posted: Thu May 27, 2010 11:44 am
Are the number of splines on the pinion different on the GV and Vitara?
Post Posted: Thu May 27, 2010 11:49 am
Should be
there are 10 on the GV not sure on vit but i dont think it 10
Post Posted: Thu May 27, 2010 12:05 pm
splines? do you mean teeth on the pinion, i think there should be a different number of teeth on the 2 different pinions.
Vehicle: jimny
Post Posted: Thu May 27, 2010 12:16 pm
so dave does this mean your not keen to catch up on sunday??
Post Posted: Fri May 28, 2010 7:08 am
Yep it's all good !!
Just that the guy that was doing it started to put the GV pinion into the alloy carrier, then was told not to worry about it :)
So yeah, Good job. I'll glue it all together tonight and get it ready to be put in tommorow arvo after work. I'll have to replace the CV boots while it's all out.
Eldo, you have pm.
Post Posted: Fri May 28, 2010 9:36 am
Thanks to all those that have helped. Very much appreciated.
I've gasket goo'd it together and left it to set, I'll torque it to FT before it go's back into the Vit tommorow.
Post Posted: Fri May 28, 2010 9:40 am
Armsup you've have alot more confidence knowing that the front diff isn't going to lunch it self at any given time!!!
Post Posted: Fri May 28, 2010 9:52 am
Yeah true, one less thing to worry about. Now I just have to worry about breaking CV's :lol:
I just have another question If you don't mind answering, I'll post it in another thread.
Post Posted: Sat May 29, 2010 12:18 pm
It took me about 9 hours to do but Ok all done.. FINALLY !!
The main things that held up progress was that the drivers side Calmini diff drop needed a little chopping so the CV could rotate without hitting it. A few bolt lining up issues, It was tricky to hold the diff up with one arm while the other finds the thread. I had to change a CV boot for the first time. :lol: and because it had been sitting there for a few weeks it was a bit hard to start, Especially with a flat battery.
But I took it for a test drive "offroad". It definitly needs a wheel alignment but it all works !! No more diahorea diff :D
The garage is a mess, and it's too late to park it in there to check for leaks. but I'm sure all is ok. I'll check it in the morning.
Oh and a bit of grease fixed a loud annoying sqeek in the rear end.
SWEEEEEET !!!!
The only other thing I need to do now Is..... Diff breathers :roll:
Vehicle: jimny
Post Posted: Sat May 29, 2010 7:59 pm
Good stuff Dave, see ya soon
Users browsing this forum: No registered users and 351 guests
