Print view
Previous topic | Next topic
| Author |
Message |
nmiller
Vehicle: 94, 3 door Vitara
 Posted: Mon Nov 09, 2015 5:02 pm |
I have a 94 swb vitara, I pulled the rear diff apart, I counted 12 bolts on the ring gear. So i bought a 1532 LR 6.9' 12 bolt from xdiff on ebay.
They responded saying this LR does not fit for my vehicle. Im confused as I have done abit of research about this and most suppliers say that this 1532 LR does fit my make and year model.
Xdiff has refunded my money. So im still keen on buying a LR, just not sure which one now
Ideas ????
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Mon Nov 09, 2015 6:00 pm |
Just buy a 1510 lockright...... It will fit and work in all Sierra, Vitara diffs and Grand vitara rear diffs. It uses your own side gears.
Ive run this model in all my diffs without a problem. And currently have one installed in my GV front diff with Vit R&P.
kingkom
Vehicle: 2003 Suzuki Grand Vitara SQ625
 Posted: Thu Jan 21, 2016 2:39 pm |
Can anyone confirm that a 1512 will fit into a GV 12 bolt rear (2003)? I've gotten my hands on one and can see many vague references to it but haven't seen anyone specifically saying yes it does work. I'm running 4xfourart ring and pinion so I don't want to swap to a Vitara centre.
Built4thrashing
 Posted: Tue Jan 26, 2016 7:06 am |
christover1
Joined: Tue Jul 15, 2008 11:30 pm Posts: 8203 Location: Melbourne
 Posted: Sat Oct 24, 2020 9:07 am |
I have not posted in AZ for a long time. But suddenly got a raft of notifications from yonks ago, but the post don't have any new stuff.
rob_macca67
Joined: Fri Sep 28, 2007 11:30 pm Posts: 367 Location: Brisbane - Nthside
Vehicle: 1993 Suzuki Vitara 4dr Wgn
 Posted: Mon Jul 27, 2026 7:10 pm |
Guys... it's been awhile since I was involved with Vitaras, but I'm starting to get back into it and my 1st question is regarding installing a spartan autolocker into the front of my vitara (steel diff). I cannot remember but from reading previous posts I can just install the Spartan locker using the single pin style (10-bolt) centre as long as I use the 4-way pin block... but I've come across a Sierra 4-pin / 10bolt centre and I'm wondering if I can use and install the spartan autolocker into it and then put this into the Vitara Steel housing? (see attached photos for reference - 1st photo is the sierra centre & 2nd is the Vitara centre)
I'm assuming I can?
_________________ '93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Users browsing this forum: No registered users and 238 guests
