It is currently Sun Oct 25, 2026 2:17 am
Vehicle: 07 vvt jimny
Post Posted: Thu Mar 04, 2010 9:53 pm
okay i got my replacement motor in connected everything sweet now i get to my dizzy and the wires that go to the coil i cant figure out which goes where ha ha ha ha
"thats what happens when u get mates ot help and they just get into it and not tell u wat they have undone and where they put them lol"
i have 2 wires comming from the dizzy 1 is branching off with a plug on it which i have plugged into its mate on the main harness on the firewall. now i have 2 left to go on the coil from the dizzy... plus. i have 2 on the coil 1 with a resistor of sum sort which is earthed then the other which is plugged into the main harness now im stuffed have tried different ways and im not getting any spark.
motor is kickin over :D just not sparkin
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Thu Mar 04, 2010 9:57 pm
There are two wires from dizzy that go to coil..
YELLOW to + side.
Black to - side.
Ring me and I'll talk you through it.
Post Posted: Thu Mar 04, 2010 10:19 pm
gday jas im out of credit mate and the mrs is out at the hospital visitin her dad and has her phone :S:S
the dizzy has
BLACK with a terminal, and a BROWN wire branching off it with a plug" there is a plug to suit comming off the main harness?
YELLOW with a terminal
then not on the coil, but attached to its brackets
BLUE with terminal with a resistor then earthing
BLACK AND WHITE with terminal which goes into the main harness
sorry CHOP :P
Post Posted: Thu Mar 04, 2010 11:32 pm
Will you be home in the morning? I'll come and have a look.
Post Posted: Fri Mar 05, 2010 1:12 am
sorry jason i missed your call man :S:S:S
that would be sweet if you could come have a look i pm'd u my details.
josh
sorry CHOP :P
Post Posted: Fri Mar 05, 2010 2:12 pm
okay i found i had a blown fuse for the ignt coil, replaced that last night and did a few ways with the wires now i am getting spark.
when i kick it over all i get it little chugs then if i try to throttle on while kicking over it back fires with real loud pops.
sorry CHOP :P
Post Posted: Fri Mar 05, 2010 2:14 pm
Did you have the dizzy out at all?
Post Posted: Fri Mar 05, 2010 2:18 pm
nope i only changed the valve cover and the sump and i put a new dizzy cap on. but yea in my manual it says backfires could be timing or loose dizzy but i aint loose lol and i havnt touched the timing :S:S
sorry CHOP :P
Post Posted: Fri Mar 05, 2010 2:33 pm
I'll see you in half hour or so.
Post Posted: Fri Mar 05, 2010 2:36 pm
to easy mate thats will be sweet just let u know though i have to leave around 10-10:30 getting my licnece renewed and then heading to my dads in caboolture
sorry CHOP :P
Post Posted: Fri Mar 05, 2010 3:48 pm
All running sweet now.... :D
Post Posted: Fri Mar 05, 2010 4:30 pm
So what was the problem?
I want my old sig back :(
Post Posted: Fri Mar 05, 2010 5:05 pm
Basically just the plug leads on the dizzy cap in the wrong order.
Post Posted: Fri Mar 05, 2010 10:39 pm
Least the carb got a clean at the same time!!! :P :P :P
Post Posted: Sat Mar 06, 2010 7:23 pm
cheers jason
ha ha ha smallest things always cause the big problems :S:S
well now i just need a radiator that isnt blocked :D:D:D:D:D
sorry CHOP :P
Post Posted: Sat Mar 06, 2010 7:30 pm
zuk85 wrote:
cheers jason
Take it to your work and use an oxy set to remove the top tank. Then shove a long dipstick down each and every tube. Refit top tank and away you go. :wink: :D
Users browsing this forum: Google Adsense [Bot] and 121 guests
