Having a few problems with 92 swb sierra G13b
Problem 1
When lights are switched on, car idles up to 2000rpm
problem 2
Battery light comes on under 1500 rpm
First of all check your belt. Is it tight enough and in good order? Then check the charge rate with a multimeter. Should be above 13v.
The idle up issue is to do with the carbie and can be adjusted.
Users browsing this forum: No registered users and 132 guests
