It is currently Sat Oct 24, 2026 11:01 am
Post Posted: Sun Mar 07, 2010 3:08 pm
hey all
ive notice the speedo has stopped working. i have had a quick look at the cable from the tcase and it all seems to be there wat else could it be ?
2''lift 31's twin locked & 6.5s
Post Posted: Sun Mar 07, 2010 3:11 pm
Pull the speedo drive out of the transfer, it might have busted the gears in there. If you stick the end of the cable in a battery drill and spin it slowly you will see if the cluster is ok.
Post Posted: Sun Mar 07, 2010 3:22 pm
2 way drill turn the clock back lol
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Sun Mar 07, 2010 3:23 pm
ok cool thanks guys ill look at that ..
Post Posted: Sun Mar 07, 2010 3:28 pm
cable has probably snapped inside the plastic sheath. or the bit that goes into the transfer has worn down and wont engage.
Post Posted: Sun Mar 07, 2010 3:37 pm
Pity it doesn't work that way :lol:
Post Posted: Sun Mar 07, 2010 4:04 pm
Have you been rooting around under the dash? You might also have pulled the cable from the back of the speedo head.
Post Posted: Sun Mar 07, 2010 4:07 pm
I found my cable tensioned in the passegers footwell last trip. :lol:
A stick underneath pulled the cable right back. (both ends were still connected)
Post Posted: Sun Mar 07, 2010 4:47 pm
yer i keep breaking mine :( custom $70 a pop
Post Posted: Sun Mar 07, 2010 4:56 pm
Custom?
Post Posted: Sun Mar 07, 2010 5:14 pm
yer, marks adapters.... it is for the engineers cert i have....
Post Posted: Tue Mar 09, 2010 2:35 am
nar havent touched that part of the dash, still gotta check it at the tcase end and do the drill check..
Users browsing this forum: Google [Bot] and 130 guests
