| nt rim off set https://auszookers.com/forum/viewtopic.php?f=5&t=10479 |
| Author: | jomclean [ Wed Mar 17, 2010 12:55 am ] |
| Post subject: | nt rim off set |
what rim off set for nt sierra about the same as wt or wider |
| Author: | steak_knife [ Wed Mar 17, 2010 1:17 am ] |
| Post subject: | Re: nt rim off set |
Same same, think thay are -5, could be wrong tho, coily's have a different offset cause nothing fit's em. |
| Author: | coneykid [ Wed Mar 17, 2010 1:41 am ] |
i running neg 27mm. 8 inch rims. realy happy with it |
| Author: | jomclean [ Wed Mar 17, 2010 11:31 pm ] |
want to get my nt the sam or a inch wider then wt |
| Author: | bogfrog [ Thu Mar 18, 2010 12:28 am ] |
jomclean wrote: want to get my nt the sam or a inch wider then wt
Then you need to put WT Diffs under it with bigger offset rims like -15's or more? |
| Author: | jomclean [ Thu Mar 18, 2010 12:58 am ] |
bogfrog wrote: jomclean wrote: want to get my nt the sam or a inch wider then wt Then you need to put WT Diffs under it with bigger offset rims like -15's or more? |
| Author: | bogfrog [ Thu Mar 18, 2010 1:56 am ] |
they are -15 off set 15x7's with 30x9.5 Maxxis Trepodore's and I also have wide track diffs as well and no scrubbing at all! |
| Author: | coneykid [ Thu Mar 18, 2010 11:36 am ] |
the tyre shop said these are the biggest offset for a suzi in a 15-8. |
| Author: | bogfrog [ Thu Mar 18, 2010 12:22 pm ] |
I think mine are off a early F100? With WT Diffs my 30x9.5's sit out from the bodyline about 100mm:
Robb. |
| Author: | coneykid [ Thu Mar 18, 2010 4:08 pm ] |
looks nice rob. i think f100 rims are 0 to neg 5mm offset. going to be scary to see how much my tyres stick out once i get wide track diffs. |
