It is currently Thu Nov 05, 2026 1:21 am
Vehicle: LPG 1.6 Sierra
Post Posted: Sat Mar 20, 2010 1:22 pm
I don't need the fuel lines in my Sierra anymore, but i'll be stuffed if I can work out how to remove the brackets that fix the fuel lines, breathers and senders to the chassis.
Any suggestions? Running straight LPG, don't need em anymore.
Post Posted: Sat Mar 20, 2010 1:36 pm
NT are bolted on...
WT are a suicide push on arrangement.
The plastic bit just pushes over the steel stud sticking out of chassis..
A large screwdriver will pry them off easily enough and then a grinder to cut the studs off.
Post Posted: Sat Mar 20, 2010 2:37 pm
Plug em at either end and leave them. Someone in the future might want fuel. Just a thought, lot easier also :wink:
Post Posted: Sat Mar 20, 2010 11:43 pm
i use my fuel line to connect front and rear diff breathers.
Post Posted: Tue Mar 23, 2010 10:13 pm
Can I drill out the suicide bolts?
Post Posted: Tue Mar 23, 2010 10:54 pm
Not really no, just grind em off, a lot easier.
Vehicle: 91 Tin Top, 04 Jimny
Post Posted: Mon Mar 14, 2011 6:39 am
I'd also like to remove the fuel lines to get a wire brush on to the chassis, but unlike che_guitarra I need my fuel lines so it might help if I put them back on when I'm finished. Has anyone sucessfully removed them and replaced them or am I being a bit of a tard? :blink:
Based on what i've read if all I can think of is prying them off, grinding the suicide bolts off, drilling them out and then tapping them, but I'd prob snap the plastic mounts getting them off me thinks....
Any light on the subject much appreciated :D
Post Posted: Mon Mar 14, 2011 11:22 am
Leave them.
You need some for your brakes anyway.. Hardly worth worrying about.
Go fix that 1mm crack in your door.
Users browsing this forum: Google [Bot] and 272 guests
