It is currently Sun Oct 25, 2026 1:04 am
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
Post Posted: Wed Mar 17, 2010 2:18 pm
If I get some F100 rims, 7's or 8's with my Couragia 31's (just over 30)
Approximately how far will tyres protrude from body work?
i have wheel flare extensions already.
It was running 32 x 16 with a -13 offset with previous owner.
Pix would be nice if anyone has this set up
cheers
christover
Post Posted: Wed Mar 17, 2010 2:28 pm
This is a wide body a guy at work has, he won't sell the rim's to me, prick.
-28 15x7's with 30x9.5's
Post Posted: Wed Mar 17, 2010 2:35 pm
Knock him on the head, give him no option :D
Thanks, that gives me a better idea than all my mathmatics can :lol:
Post Posted: Wed Mar 17, 2010 2:43 pm
Being the v6 he had to grind the caliper a fair bit to get em to fit, & thay only JUST fit, yours should be fine as far as brake's go, just the sticky outy bit. :roll:
Vehicle: SJ51T
Post Posted: Wed Mar 17, 2010 2:48 pm
heres mine
there 15x7 -12 with 30x9.5
they probably sit about 2" out of the guards.
Post Posted: Wed Mar 17, 2010 2:49 pm
LWB has bigger brakes apparently, so hope that don't affect anything.
May be why it had 16's on it before.
I'd better look into that, cheers
christover
Post Posted: Wed Mar 17, 2010 2:51 pm
matty_wall wrote:
heres mine
that would be perfect, I have 50mm wheel flares
thanks
christover
Vehicle: SJ51T
Post Posted: Wed Mar 17, 2010 2:56 pm
christover1 wrote:
matty_wall wrote:
heres mine
thanks
christover
no worries
your brakes shouldn't be a problem with 15s either. standard 1.6l LWB came with 15's.
Post Posted: Wed Mar 17, 2010 2:58 pm
Stekky they are -13 not 28, somebody cant work a tape and maths
I have same, with 235's they use every bit of my 50mm clark rubber flares
Brakes will be fine, its the later widebody ones and GV's with the different rotor offset thats trouble
Post Posted: Wed Mar 17, 2010 3:05 pm
So he lied to me!!! :evil: :evil:
Yer knew about the brake's, his had to be shaved a fair bit to fit 15's on.
A vit will be fine tho..
Post Posted: Wed Mar 17, 2010 3:16 pm
thanks all.
Knowing what I need is half way there ..
Now to make it happen some how
Post Posted: Wed Mar 17, 2010 3:26 pm
you'll also have clearance dramas on the rear of the wheel arch that a hammer sorts out, larger tyres will still hit even with a bodylift so some cutting needs to be done, moving the wheels forward a bit helps a lot as well
Post Posted: Wed Mar 17, 2010 3:36 pm
Guards were done by previous owner to suit 32's on 16 x7's, so I'm hoping it will be right already for 31's on 15 x7 or 8.
That will depend on offset and rim width, too, I guess.
Time will tell.
christover
Post Posted: Wed Mar 17, 2010 3:44 pm
with previous owners 32's x16 x 7" on it
Post Posted: Wed Mar 17, 2010 4:53 pm
32's? they look like 30's to me. Look good though
Post Posted: Wed Mar 17, 2010 4:56 pm
Its true they do look small, but it must be a 16" rim thing, cos they tall n skinny, they dont look big.
Vehicle: SJ51T
Post Posted: Wed Mar 17, 2010 5:49 pm
Yeah my next set of tyres will be 32x9.5 hopefully. did you drive it with those tyres on? How much scrubbing and where?
Mathew
Post Posted: Wed Mar 17, 2010 6:13 pm
Mathew
Never drove it with 32's on, but no obvious signs of rubbing any where.
It has got bump stop spacers as well as guard massaging
Vehicle: SJ51T
Post Posted: Wed Mar 17, 2010 6:23 pm
christover1 wrote:
Mathew
ohh yerr i gota do that anyway before my como shocks shit them selves.. thanks for the info, ill give them a go next time.
Post Posted: Wed Mar 17, 2010 9:04 pm
so there origanal f100 rims of a ford
Post Posted: Wed Mar 17, 2010 9:08 pm
It has to be from a 4wd f100, or the free wheeling hub won't fit thru.
But stud pattern is same.
Post Posted: Wed Mar 17, 2010 9:10 pm
Ford F100 , yes
Post Posted: Wed Mar 17, 2010 10:26 pm
do they bolt straight on or do i need to modify the holes
Post Posted: Wed Mar 17, 2010 10:28 pm
Bolt straight on
Post Posted: Wed Mar 17, 2010 10:29 pm
Same same, there is a 6 stud that won't fit.
Post Posted: Thu Mar 18, 2010 3:16 am
They would have to be 235/85/16s tyres wouldn't they, as thats the only real common tall/narrow size for a 16" rim? They come out to about 31.6" overall.
They actually look pretty damn good on that, gives that extra bit of clearance and they actually look less cop bait then the usual smaller diameter but wider tyres. Pretty good price wise as well for a 16" tyre.
Narrower tyre probably helped a shitload with the clearance also. Interesting...
Moses' SQ625 GV Pig
Post Posted: Thu Mar 18, 2010 12:03 pm
Yes I think that is the size, he is fitting his 32's to a LWB Sierra, I think.
I like 31's due to the fact that they are aplenty anywhere in Aus, and cheaper in the outback, than rarer sizes.
Plus I have some already, and the rims be cheaper, too.
christover
Vehicle: SJ51T
Post Posted: Thu Mar 18, 2010 12:21 pm
yep, all those reasons are why im looking at getting a set :wink:
Only problem is i need to find some GV steel rims and i have no idea how they will sit in terms of offset. I hope they sit inward a little so they don't hit my guards.
From what i can find there one of the few tyre sizes that measure close to 32x9.5 and arent a very aggressive tread like simex extreme trekker (i think)
Post Posted: Thu Mar 18, 2010 12:23 pm
I'm pretty sure the 16"rims were Kings with a -13 offset
Vehicle: 94 Vitara LWB
Post Posted: Sat Mar 20, 2010 3:01 am
Not saying for sure your wrong Royce , as I have Kings with a -13 offset on my Vitara LWB and from what I've seen the F100 rims have a greater offset again. Mine only just sit proud of the guards . Mine are also 15inch rims and the calipers needed a little grinding whereas the F100 rims didn't need the grinding.
Not sure if this is relavant but I can get photo's and check measurements if needed.
Users browsing this forum: No registered users and 242 guests
