It is currently Sun Oct 25, 2026 4:00 pm
Poll: whats your pick?
ebay no-name 8%  8%  [ 1 ]
branded damper 75%  75%  [ 9 ]
heavy duty eg. rancho 17%  17%  [ 2 ]
Total votes : 12
Post Posted: Mon Mar 29, 2010 4:24 pm
before you all get fired up i have searched :wink:
ive only had my 85 sierra for a few weeks now but its evident the steering damper is useless. its to be expected as im pretty certain its the stocker that came on it 25 years ago.
ive looked around but havent seen much info on what type to get, most stuff is about vibration/steering setup/alignemnt etc. also had a look through a mates stack of 4wd mags but nothing in them apart from ads.
so whats the difference between
car is used for road(50%), sand(30%), bush(20%) driving
and if it makes a difference it runs 215/75/15 Mud Terrains
Think before you post to make AZ a better place :)
Post Posted: Mon Mar 29, 2010 4:49 pm
I found that on my bundera going from the flogged out rancho one that was on it to a brand new dobinsons one it almost totally eliminated all of the steering wobble the car had and the steering was much nicer on and off road
I would like to hear peoples opinions on the RTC ones though...I think the one on my zook is flogged out and requires replacement
95 W/T - Got a few bits
Vehicle: MY2019 Jimny
Post Posted: Mon Mar 29, 2010 5:14 pm
RTC for me was crap.
A stock one will be fine for a stock car, but if you use larger tyres I would go for an iron man or something.
BTW I am not fussed with Ranchos.
Post Posted: Mon Mar 29, 2010 5:23 pm
I had a Tough Dog one. $99. Its really just a shock. Possibly valved different for sideways movements.
RTC was $150 when i was looking at them. (2yr ago)
Now i run Powersteering with no damper.
Useless suzuki info: Coilys don't have dampers. Not even mounts..
Post Posted: Mon Mar 29, 2010 5:27 pm
I purchased a ebay one when I put 29" tyres on and a 50 mm spring lift on a 91 swb wt It had the rattles bad!!
Ebay one worked a treat no more rattles and shakes. That was a couple of years ago and now have the rattles back which I think is now due to worn bits.
98 GV
Post Posted: Mon Mar 29, 2010 5:29 pm
For the record I have been without a steering dampener for over 2 years, not an issue if your steering geometry is good.
Post Posted: Mon Mar 29, 2010 5:33 pm
Rockclimbing any 4x4 'with' a damper throws the steering wheel out of your hand if you hit a rock on one side.
Powersteering does not! 8) 8) 8) 8)
Post Posted: Mon Mar 29, 2010 6:17 pm
i dont use a steering damper as my steering is spot on.
RTC on my jimny with power steer was good for centering the wheel on the motorway but made no difference other than that.
Normal damper often makes steering in sierra a bit heavier, i would avoid the RTC on sierra as it gives preference in a certain turning direction- Shock that is used in normal dampers has its static position set at half-way, RTC shocks want to push the rod out, spring is supposed to stop this but fails
Post Posted: Mon Mar 29, 2010 8:12 pm
Im using an Ironman dampner on mine, its actually from a 40 series.
Users browsing this forum: No registered users and 134 guests
