| who can make a simplified wire and go loom for this motor? https://auszookers.com/forum/viewtopic.php?f=5&t=10677 |
| Author: | MR1JZ [ Fri Mar 26, 2010 5:53 pm ] |
| Post subject: | who can make a simplified wire and go loom for this motor? |
My mate has fitted this motor to his zook (all of the mechanical work has been done) he just needs to wire it and has no idea how to
Its an M16A from a vit...all of the gearbox mounting and other associated junk has been done but we cant find anyone locally to wire it...can anyone interstate or locally? make a loom up for us to give it the necessary powers and earths and what not so we can get it chugging along? Thanks Matt P.S. It has a complete loom, ecu, fusebox etc |
| Author: | Ben_Sierra [ Fri Mar 26, 2010 6:45 pm ] |
| Post subject: | Re: who can make a simplified wire and go loom for this moto |
I don't believe the M16A was ever installed in the Vitara... Liana's, SX4's and Swift Sports only I think... Your best bet may be to take it to a competent auto electrician to do all of the wiring if you are not confident of doing it yourself.. |
| Author: | MR1JZ [ Fri Mar 26, 2010 6:47 pm ] |
if someone can chop up the loom and label it for the basics (it cant need much as a lot of it is from a later model car with crap the zook doesnt have or need) we can handle it...we dont want it done for free either! so it could be an SX4 motor it is an M16A yeah? |
| Author: | Ben_Sierra [ Fri Mar 26, 2010 6:50 pm ] |
If its a 1.6, DOHC Suzuki engine I'd say so... |
| Author: | losfer [ Sat Mar 27, 2010 7:33 pm ] |
Ben_Sierra wrote: I don't believe the M16A was ever installed in the Vitara... Liana's, SX4's and Swift Sports only I think...
Your best bet may be to take it to a competent auto electrician to do all of the wiring if you are not confident of doing it yourself.. grand vitara came out with m16a , JB416 |
| Author: | losfer [ Sat Mar 27, 2010 7:51 pm ] |
ohh and your mate is in a world of pain to get that running in his sierra , the cheapest option would be an aftermarket ecu . cant remember off the top of my head but it has something to do with the immobiliser or body control management (im thinking immobiliser) |
| Author: | MR1JZ [ Sat Mar 27, 2010 9:52 pm ] |
losfer wrote: ohh and your mate is in a world of pain to get that running in his sierra , the cheapest option would be an aftermarket ecu . cant remember off the top of my head but it has something to do with the immobiliser or body control management (im thinking immobiliser)
crap...can anyone confirm this? |
| Author: | eldo [ Sat Mar 27, 2010 9:54 pm ] |
I'm sure there is a m18 done already isn't there? Maybe search m16??? |
| Author: | BlueSuzy [ Sat Mar 27, 2010 9:56 pm ] |
If you have the key and the ignition, it should be better... A chip is in the key for the immoboliser.. Looks like an 'm' motor on a 'g' series sierra box! |
| Author: | MR1JZ [ Sat Mar 27, 2010 10:21 pm ] |
it is an M motor on a G box custom engine mounts and adaptor plate...all done quite well |
| Author: | atari4x4 [ Sat Mar 27, 2010 10:54 pm ] |
if you can track down a immobiliser transponder & a blank key it can be made to work. StupidZooK had to do it when putting an EJ25 out of a forester into a L Series Subaru. |
| Author: | zookfun [ Sun Mar 28, 2010 5:54 am ] |
have you got the engine bay loom? Have you got a wiring diagram? Ive just wired a g13b into a sierra so could possibly help... |
| Author: | MR1JZ [ Sun Mar 28, 2010 2:33 pm ] |
has everything dude...you got a number I can give to my mate so you can have a suss? |
| Author: | zookfun [ Tue Mar 30, 2010 4:06 am ] |
yeah ill send a msg |
| Author: | MR1JZ [ Tue Mar 30, 2010 10:55 am ] |
thanks mate...it looks like he may just be putting an adaptronic on it as that will do VVTI and isnt too expensive |
| Author: | sj80tourer [ Tue Mar 29, 2016 1:26 pm ] |
Did this ever get up and running ??? |
| Author: | MrRocky [ Tue Mar 29, 2016 1:34 pm ] |
All u gotta do is tape key in ignition and leave it tucked under the dash. Less than ideal but no way to bypass coded key |
| Author: | atari4x4 [ Tue Mar 29, 2016 1:43 pm ] |
sj80tourer wrote: Did this ever get up and running ??? MR1JZ Last visited: Mon May 02, 2011 9:12 pm Im guessing that's a
| Author: | greenzook89 [ Tue Mar 29, 2016 9:44 pm ] |
Oh no. Not a UFP. |
