It is currently Sat Oct 24, 2026 11:01 am
Post Posted: Sun Mar 28, 2010 11:57 pm
Hi All,
Leaking around the speedo cable. Is it just as simple as removing and replacing o-ring???
Rusho
Post Posted: Sun Mar 28, 2010 11:59 pm
no, youll need to catch the spilled oil and refill the transfer too :)
yeh.. that is one of the leaks i had in mine.
other one is comif fom up high
i would wash it down and clean properly then go for a drive to confirm that it isnt somewhere else and just looks like the speedo drive.
Post Posted: Mon Mar 29, 2010 12:09 am
Definately just speedo..Its only a o-ring though? Just wanna know if i need to order anything special. It is a coily after all pompoms
Post Posted: Mon Mar 29, 2010 12:10 am
Rusho81 wrote:
Definately just speedo..Its only a o-ring though? Just wanna know if i need to order anything special. It is a coilt after all pompoms
oh yeh i forgot you had one of those ones
Post Posted: Mon Mar 29, 2010 2:19 am
If some one has had it apart and didnt take the speedo out first the case can crack. just have a quick look at the hole when you have it out. but 99% sure it will just be the o-ring.
Post Posted: Mon Mar 29, 2010 2:28 am
cheers for the warning
Users browsing this forum: Google [Bot] and 127 guests
