| Leaky T'fer https://auszookers.com/forum/viewtopic.php?f=5&t=10728 |
| Author: | Rusho [ Sun Mar 28, 2010 11:57 pm ] |
| Post subject: | Leaky T'fer |
Hi All, Leaking around the speedo cable. Is it just as simple as removing and replacing o-ring??? Cheers Rusho |
| Author: | royce [ Sun Mar 28, 2010 11:59 pm ] |
| Post subject: | Re: Leaky T'fer |
no, youll need to catch the spilled oil and refill the transfer too |
| Author: | 89_tintop [ Sun Mar 28, 2010 11:59 pm ] |
yeh.. that is one of the leaks i had in mine. other one is comif fom up high i would wash it down and clean properly then go for a drive to confirm that it isnt somewhere else and just looks like the speedo drive. |
| Author: | Rusho [ Mon Mar 29, 2010 12:09 am ] |
Definately just speedo..Its only a o-ring though? Just wanna know if i need to order anything special. It is a coily after all
| Author: | 89_tintop [ Mon Mar 29, 2010 12:10 am ] |
Rusho81 wrote: Definately just speedo..Its only a o-ring though? Just wanna know if i need to order anything special. It is a coilt after all
![]() oh yeh i forgot you had one of those ones |
| Author: | v.w.dave [ Mon Mar 29, 2010 2:19 am ] |
If some one has had it apart and didnt take the speedo out first the case can crack. just have a quick look at the hole when you have it out. but 99% sure it will just be the o-ring. |
| Author: | Rusho [ Mon Mar 29, 2010 2:28 am ] |
v.w.dave wrote: If some one has had it apart and didnt take the speedo out first the case can crack. just have a quick look at the hole when you have it out. but 99% sure it will just be the o-ring.
cheers for the warning |
