che_guitarra wrote:
Also looking to clear up the throat, so if you can remove the main jet, let me know how. Not sure what the two hoses marked with a green X in pic #4 are either, but they're now part of my LPG setup - just wanting to know their function.
Here's the pics - i've kept them numbered and colour coded so hopefully it's easier to navigate:
purple section with two hoses marked xx in pic 4 is the coolant for auto choke.
Yellow in pic one is the part which stops it stalling if you close the throttle/butterly valves quickly.
orange in pic 1 is the vacuum to pull the choke butterfly valve open.
red in pic 1 allows secondary jet to open at wot.
green in pic 3 is the fuel float breather
purple in pic 3 is choke set up
i dont see a pic of the idle up control. it would be just around the corner of the yellow section on pic 1
it appears your idle up has been removed already going by pic 3.
download the manual if u want more info
