It is currently Mon Oct 19, 2026 10:38 pm
Post Posted: Thu Jul 13, 2006 5:25 pm
Is it possible to fit a front NT Diff to the rear of the same vehicle...they look identical.
thanks
Post Posted: Thu Jul 13, 2006 5:41 pm
seeing as it is Narrow track 1.3,
yes it can be made to fit
no its not a straight swap
every component is identical bar the side gears, these are the gears the inside the diff that the axles slide into
Providing we arent talking welded or locker equipped diffs, you can pull the centre apart and swap the gears to the ones to suit either front or rear, its not hard but involves reseting the backlash and bearing preload which is fiddly and a bit hit and miss without the proper tools
note this only works for NT diffs, WT use a 2 pin front diff and 4 pin rear diff (same as NT) and the side gears cant be swapped
Post Posted: Fri Jul 14, 2006 1:18 pm
Thanks Royce.
Bit of a shame, but it's best to know before trying to make it fit.
So a WT rear diff (if it was 4.11 rather than 3.9) would swap straight into the back of the NT.
Vehicle: 75 Cruiser
Post Posted: Fri Jul 14, 2006 1:31 pm
yeah you can put NT diff centers in WT housings, and visa versa.
I use to have NT centers in my red zook.
Post Posted: Fri Jul 14, 2006 1:47 pm
NT 1.3 = 3.9
WT 1.3 = 3.7 these are interchangable in pairs
Maruti WT = 4.11 and will interchange with above (long as its wide track)
1litre NT 4.11 and different to above, not interchangable
LJ stuff can be swapped around with NT 1 litre stuff but its a fiddle
