It is currently Sun Oct 25, 2026 2:18 am
Post Posted: Mon Apr 05, 2010 8:11 am
hey,
after going out saturday and my clutch stopping working i pulled the gear box off today. I found that the clutch realease bearing wasn't connected to the clutch fork. The small pin that is pressed into the clutch fork and holds the realease bearing has snapped off.
How do i go about fixing this?
Post Posted: Mon Apr 05, 2010 12:17 pm
Remove the fork assembly and punch out broken pin, then press in a new piece of hardened steel...
OR
Remove fork and replace with another 2nd hand one.. Probably easier..
Removing the fork is a bitch of a job. Have fun.
Post Posted: Mon Apr 05, 2010 1:11 pm
replace gearbox if u have a spair much easyer
Post Posted: Mon Apr 05, 2010 3:14 pm
drill it out and weld a bolt same dimensions through, or just bolt the bearing on through the hole, just make sure it doesnt come off, use heaps of locktite and a spring washer or nylon locking nut.
had a big night so this may not make sense
Post Posted: Mon Apr 05, 2010 7:14 pm
i was having a look at it and can't really work out how you remove the fork assembly. Any tricks to getting it out?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Tue Apr 06, 2010 3:21 am
just drill it and put a bolt in
Post Posted: Thu Apr 08, 2010 12:54 am
managed to press the old pin out wth some multi grips. Then got the pin out of the 1L gear box i got off you MrRocky and pressed that in.
All fixed i think :/ ...will get a new throwout bearing tomorrow and pop the gearbox back in...fingercrossed the gearbox is all good, i did have to drive pretty far home with no clutch at all. :(
79' LJ80 (sold) :(
Post Posted: Thu Apr 08, 2010 1:28 am
I would have used some locktite when you pressed it in.
Glad to here my 1ltr box came in handy for something, im guessing it never did end up in the LJ
Post Posted: Thu Apr 08, 2010 2:06 am
yeah i put a little locktite in there, hopefully it holds.
na, i'm going to use the orginal LJ box with your 1L engine.
79' LJ80 (sold) :(
Users browsing this forum: Google Adsense [Bot] and 110 guests
