It is currently Sun Oct 25, 2026 4:33 am
Post Posted: Mon Apr 05, 2010 2:12 pm
hi there just lokking for information as to why and what would be causing bouncing of the front end
Vehicle: LJ20 LJ50
Post Posted: Mon Apr 05, 2010 2:18 pm
out of round front tyre
broken shock
Camels have nice toes
Post Posted: Mon Apr 05, 2010 2:23 pm
i own 97 siera with coil suspensin
Post Posted: Mon Apr 05, 2010 2:34 pm
broken shock
Duzn mada what you have, coil or leaf springs, a fukd set of shockies will do the trick every time,
Post Posted: Mon Apr 05, 2010 2:35 pm
We'll need a little more info, like when it does it, speed etc. Any mods to the car? Does sound like a broken or worn out shock to me
Post Posted: Mon Apr 05, 2010 3:12 pm
if it does it under acceleration it could be axle tramp.
if its constantly no matter what speed its rims/tyres.
other options are an engine mount or tcase mount broken, but thats normally just a mad vibration, not front only.
Post Posted: Mon Apr 05, 2010 6:52 pm
It's called "death wobble" and most of us have experienced it at one time or another. It can become so bad the front of the starts bouncing off the road surface, like a lowrider, but somehow not as cool :wink:
It's generally a combination of a whole lot of little things. ANY play anywhere in the front end might be enough to start it, so check everything - Wheelbearing tightness, ball joints, panhard rod bushes, shock bushes/condition.
Also, swivel seals act as dampers on the steering- If they're worn, it will be easier to trigger.
It's unlikely it's being caused by out of round tyres. If the front iend is working properly, an out of round tyre should give steering shimmy, but no more - certainly not death wobble.
As an example - a mate runs a WT SWB with offset beadlocked rims and Q78 swampers, unbalanced. It has no steering damper. It's never deathwobbled at any speed until he put stock tyres back on it.
I've never had death wobble with my flogged old Q78's on my sierra, but another mate tried them on his SWB and it deathwobbled like a fiend.
Like I said - it's likely to be a lot of little things. Make sure all front end stuff is to spec.
Post Posted: Mon Apr 05, 2010 10:41 pm
steve yours is probably not wobbling cos everything has worn on it causing all the wobbles to equalise each other =D
Users browsing this forum: No registered users and 164 guests
