| h25 or h27 into early v6 vitara https://auszookers.com/forum/viewtopic.php?f=5&t=10876 |
| Author: | andymac_81 [ Mon Apr 05, 2010 4:28 pm ] |
| Post subject: | h25 or h27 into early v6 vitara |
was just wondering if anyone has done the conversion and whats involved |
| Author: | atari4x4 [ Mon Apr 12, 2010 7:17 pm ] |
| Post subject: | Re: h25 or h27 into early v6 vitara |
being a "H" series motor it should bolt straight in, i'm guessing the pin out's & the ECU are going to be slightly different. i'm keen to do the swap on my 2.0l 4cyl SV420 Vitara one day. |
| Author: | joeblow [ Mon Apr 12, 2010 8:58 pm ] |
atari4x4 wrote: being a "H" series motor it should bolt straight in, i'm guessing the pin out's & the ECU are going to be slightly different.
i'm keen to do the swap on my 2.0l 4cyl SV420 Vitara one day. I've done a H27 in one of them.........
| Author: | Joe [ Mon Apr 12, 2010 9:45 pm ] |
joeblow wrote: atari4x4 wrote: being a "H" series motor it should bolt straight in, i'm guessing the pin out's & the ECU are going to be slightly different. i'm keen to do the swap on my 2.0l 4cyl SV420 Vitara one day. I've done a H27 in one of them......... ![]() Got any pics |
| Author: | atari4x4 [ Tue Apr 13, 2010 2:50 am ] |
joeblow wrote: atari4x4 wrote: being a "H" series motor it should bolt straight in, i'm guessing the pin out's & the ECU are going to be slightly different. i'm keen to do the swap on my 2.0l 4cyl SV420 Vitara one day. I've done a H27 in one of them......... ![]() what haven't you done to a zook??? did you have any major issues with the wiring side of things & did the motor just fall in & all line up like it should?? |
| Author: | hophoar [ Tue Apr 13, 2010 3:44 am ] |
Just finished putting a 2.5 into a 95 lwb, it was all plug and play. |
| Author: | dezook [ Tue Apr 20, 2010 3:32 am ] |
Check my ride thread and you will see many pics of a 2.5 going into a 1.6 G16b Not as easy as into a V6 though. |
| Author: | dezook [ Tue Apr 20, 2010 3:33 am ] |
In the rigs of auszookers, Can't miss it. |
| Author: | robbo [ Tue Apr 20, 2010 1:01 pm ] |
Go the 2.7. The extra power and torque is going to make u happier in the long run. not alot of extra fab work between the 2.5 or 2.7 |
