It is currently Sat Oct 24, 2026 11:27 pm
Post Posted: Tue Apr 06, 2010 1:23 pm
how do i easily isolate the sparky bits for my winch? from memory it draws up to 450amps.
i have had a bit of a look around and haven't found anything over 200amp.
so whats the go? what should i use?
Post Posted: Tue Apr 06, 2010 1:36 pm
Group some ciruit breakers together on the positive wire. Superwinch used to do that years ago.
Post Posted: Tue Apr 06, 2010 1:45 pm
I run a 500/100 fuse...
It is rated at 500A draw or 100A dead short.. Don't ask me how it works, I dunno... Just looks like an ordinary fuse....
I got it off ebay..
Looks like this....Image
Goes in this... Image
Available from here.... http://stores.shop.ebay.com.au/Derek-Be ... QQ_armrsZ1
Post Posted: Tue Apr 06, 2010 2:00 pm
Cole Hersee battery switch, if they dont die on a winch Patrol with a rewound motor and 24v I doubt they ever will
Vehicle: SJ80, SE416
Post Posted: Tue Apr 06, 2010 2:06 pm
Narva Part no. 61090
310A at 12V continuous load maximum
500A at 12V for 5 minutes
I know repco and the like can order these in.
http://www.narva.com.au/products/browse/battery-master
I don't know what they are worth, but 61075 cost me about $120 last year, so i'm guessing it'll cost more than that.
Another avenue worth investigating would be the screw type isolation switches mounted directly on battery terminals. I think I have seen them in supercheap but they probably aren't rated to 450A and that would isolate everything - not just winch. Why do you want to isolate the winch when they already have a solenoid box that does that?
Post Posted: Tue Apr 06, 2010 3:59 pm
Just use a winch solenoid , which are rated the same as the winch , then use a relay and switch to turn it off and on , Cheers Paul.
Users browsing this forum: No registered users and 1272 guests
