Do I have to lift my front end up to remove the bar? Read through my manual real quick and it said that you have to lift it till it's aligned with some markings or something, but a few people have said you can do it on the ground.
Can you slide the sway bar off the suspension arms without having to remove the bolt? Seems the bolt is also holding the arm to the chassis :s
Users browsing this forum: Google [Bot] and 163 guests
