It is currently Sun Oct 25, 2026 2:18 am
Vehicle: SJ50 hardtop!
Post Posted: Wed Apr 07, 2010 7:16 pm
Do I have to lift my front end up to remove the bar? Read through my manual real quick and it said that you have to lift it till it's aligned with some markings or something, but a few people have said you can do it on the ground.
Can you slide the sway bar off the suspension arms without having to remove the bolt? Seems the bolt is also holding the arm to the chassis :s
NT SJ50
Post Posted: Wed Apr 07, 2010 8:46 pm
undo the link from teh arm, then the swaybar, I pulled mine off in a paddock
the bar will sit where you leave it, mine still in there after 4 years
Post Posted: Wed Apr 07, 2010 9:43 pm
so take the ball joints out first so the sway bar moves a bit, then take the nut off the suspension arm bolt and slide swaybar out?
NT SJ50
Users browsing this forum: No registered users and 119 guests
