It is currently Sat Oct 24, 2026 6:48 pm
Vehicle: 30s front locker barwork
Post Posted: Thu Apr 08, 2010 11:42 pm
hey guys i have lost my speedo at first i thought it was the cable because the end that went in to the transfer case had snaped so i have bought a new one n fited it but it still doesnt work. when i roll the car u can see the gear in the transfer moving and when i spin the speedo cable u can see the cluster move. so i am stuped on wat it can be so any help would be great.
cheers
Post Posted: Thu Apr 08, 2010 11:46 pm
So if the cable is making the speedo move and the gears are moving in the transfer then it must be something to do with the end of the cable, the way the gears are meshing (or not). Have you pushed the drive gear in far enough? Does it feel like it meshes properly?
Post Posted: Thu Apr 08, 2010 11:49 pm
yeah cable isnt into the transfer end properly
Post Posted: Thu Apr 08, 2010 11:58 pm
it goes in all the way i think i will have another look tomorrow n will get back to u guy
Post Posted: Fri Apr 09, 2010 12:48 am
I take it you checked the new one works correctly , Cheers Paul.
Post Posted: Fri Apr 09, 2010 1:18 am
it sounds like it is not in the transfer properly
Post Posted: Fri Apr 09, 2010 7:31 am
if both ends work properly there must be a incorrect connection either in the speedo or mos likely not pushed into the transfer case enough
Users browsing this forum: No registered users and 233 guests
