https://auszookers.com/forum/
idling high
https://auszookers.com/forum/viewtopic.php?f=5&t=11104
Author:  lyndon123 [ Tue Apr 13, 2010 3:29 pm ]
Post subject:  idling high
Hi guys, im very new to sierras and have just picked up my first one..
since i have had it its been idling high, i beleve its because the previous owner has advanced the timing, as i set it back to std and it was idling fine, but that stopped me from getting upto 100kph witch is dangerous cause i live on a highway, i was just wondering how to bring my idol back down to less than 1800rpm and when i turn lights on its well over 2300rpm and its very annoying
thanks in advance
Author:  Ben_Sierra [ Tue Apr 13, 2010 3:35 pm ]
Post subject:  Re: idling high
There is an idle adjustment screw on the side of the carb. Someone here will have a pic...
But a high idle iteslf wouldn't prevent you from reaching 100kph, so something else is not quite right either...
We'll need more info to diagnose...
Author:  royce [ Tue Apr 13, 2010 3:38 pm ]
pull the top air intake thingo off your carb and first check the choke is fully turning off when its up to temp
the idle screw is accesed from teh passengers side rear of the carb, its part of the throttle linkage
for the high idle when lights are on, get somebody to turn the lights on and watch the front of the carb you will see a vacuum actuator move, its adjustment screw sets the high idle
Author:  SJ70MOZ [ Tue Apr 13, 2010 8:46 pm ]
what should it idle at with the lights on?
Author:  royce [ Tue Apr 13, 2010 9:07 pm ]
they have a setup to up the idle speed with high electrical loads, which is lights and heater fan, stop the battery going flat
Author:  foolsp33d [ Tue Apr 13, 2010 9:28 pm ]
this can also be checked by unplugging the electrical plug on the front of the carb. and listening for the click IIRC..idle up we are talking here... you could also turn your headlights on and disonnect the vacume line to the idle up thingamabob..
It would also be worth checkingwhere your accelerator bolts into the cab. I noticed driving today mine has deeloped a bit of a loose bolt syndrom and its causing the pedal to not return .. i physically have to lift it with my foot between gear changes and when slowing down.. is a RIGHT PITA!
Author:  SJ70MOZ [ Tue Apr 13, 2010 10:15 pm ]
yea i understand what the stepup solenoid is for but i don't know what rpm the motor should run at when its under electrical load. Turn my lights on and it bumps it up to 2grand!
Author:  Rhino [ Tue Apr 13, 2010 10:34 pm ]
Mine rises by close to 500rpm for lights then same again if i switch the fan on.
Author:  jdk81 [ Tue Apr 13, 2010 10:41 pm ]
idle at 850 rpm.
high idle around 1300 rpm or so is fine, check the manual
EDIT: manual is in download section
Manual says 1000 rpm.
Mine idles higher when I turn the parkers on because there is almost no load, once the headlights are on the rpm drops down as the alt is supplying the power for the lights (2 x 130/90W).
Author:  SJ70MOZ [ Tue Apr 13, 2010 11:11 pm ]
yea that makes sense. Thanks for the advice guys and sorry to lyndon123 for hijacking ur thread
Author:  royce [ Tue Apr 13, 2010 11:26 pm ]
ha lol sorry teach me for not reading properly
I unplugged mine, unless you are up around 2 grand its not really helping :)
Author:  Che [ Tue Apr 13, 2010 11:43 pm ]
Is there another way to adjust idle?
I recently replaced my accelerator cable and it was about 1/2 cm shorter than the one it replaced. Idle speed screw is wound out as far as it'll effectively go, so too the new accel cable (where the thread/bolts fix onto the carby attachment) - it can't be lengthened any more without falling off the thread.
Idle speed is still 1300 RPM and I can't drop it anymore.
Author:  Ben_Sierra [ Wed Apr 14, 2010 12:49 am ]
Get the right length cable....
There should be a small amount of freeplay in the cable at idle...
If there isn't and the cable is wound right out, aint nothing gonna fix it...
Author:  SJ70MOZ [ Wed Apr 14, 2010 2:18 am ]
so having not plugged in hasn't caused any problems? Or have u up graded ur alt?
Its only going to make a difference at idle isn't it, so if ur not idling for long periods the charge rate shouldn't really be affected. Am i on the right track?
Author:  Ben_Sierra [ Wed Apr 14, 2010 2:27 am ]
Yes, it only makes a difference at idle.
All the time your driving around it will be fine.
