| Indicator Electrics https://auszookers.com/forum/viewtopic.php?f=5&t=11142 |
| Author: | pyrohamish [ Wed Apr 14, 2010 10:16 pm ] |
| Post subject: | Indicator Electrics |
So I've been playing with the wiring alot, now my indicators wont work, but the will work when hazards are on. Any ideas as to what I've f**ked up? Is it possible that I've burnt out one side of the flasher unit or something? and is there anyway to test what you think is wrong? |
| Author: | Ben_Sierra [ Wed Apr 14, 2010 10:53 pm ] |
| Post subject: | Re: Indicator Electrics |
I had issues with my indicators not working properly... Was a bad earth. Recheck the wiring where you've been playing with it! |
| Author: | pyrohamish [ Thu Apr 15, 2010 12:41 am ] |
earths are good, I'm confiden about that, all go back to 1 bolt |
| Author: | Ben_Sierra [ Thu Apr 15, 2010 1:15 am ] |
Mine did too, but the connection there was crap... |
| Author: | jdk81 [ Thu Apr 15, 2010 1:17 am ] |
Umm what about your reverse lights? Hazards are on a diff fuse to the indicators (which are on the same fuse as the reverse lights). |
| Author: | pyrohamish [ Thu Apr 15, 2010 2:05 am ] |
ahh that could be it What colour wires go to the fuse? |
| Author: | Benz [ Thu Apr 15, 2010 4:19 am ] |
as jdk81 said hazards are on a different fuse. and reverse should be one the same fuse as the indicators =] so you have blown a fuse. if its not that then its fault finding time! YAY! |
| Author: | BlueSuzy [ Thu Apr 15, 2010 4:39 am ] |
reverse, i've blown a switch in the gbox, i just swapped switches with another on the gbox. Like, take the switch out and swap it. not just swap wires |
| Author: | jdk81 [ Thu Apr 15, 2010 11:24 am ] |
BlueSuzy wrote: reverse, i've blown a switch in the gbox, i just swapped switches with another on the gbox.
Like, take the switch out and swap it. not just swap wires Thats how I found out about the circuits |
