| is a baleno motor the same as a vitara? https://auszookers.com/forum/viewtopic.php?f=5&t=11145 |
| Author: | manup [ Wed Apr 14, 2010 11:29 pm ] |
| Post subject: | is a baleno motor the same as a vitara? |
hi, im just looking at doing a motor transplant to my sierra and lookin for a cheaper way. is a suzuki baleno motor the sane as a vitara? g16b???? |
| Author: | hooki [ Wed Apr 14, 2010 11:36 pm ] |
| Post subject: | Re: is a baleno motor the same as a vitara? |
i think the inlet manifold and sump/oil pickup are different. Heaps of people still use them though. |
| Author: | ODA1 [ Thu Apr 15, 2010 12:03 am ] |
Looking under my bonnet and if I didn't know it was a baleno I would say it's a vitara engine |
| Author: | manup [ Thu Apr 15, 2010 12:24 am ] |
so if i had a baleno motor and looking for extractors, vitara 4x4 extractors would fit? |
| Author: | manup [ Thu Apr 15, 2010 12:48 am ] |
and use a baleno intake? i would love to see pics if anyone has done the conversion |
| Author: | BlueSuzy [ Thu Apr 15, 2010 1:34 am ] |
Look in my buildup. I have a 98+ baleno g16b in a sierra. There are various differences. Ignition types Water Different sensors Etc. You can use vit g16b extractors and jimny g13b ones Hit me with a question, and i will answer it |
| Author: | ninjadaniel [ Thu Apr 15, 2010 1:19 pm ] |
ya you need to use the baleno wiring loom, ecu as the sensors are different to vitara, make sure to get a baleno engine that uses COP (coil on plug) setup, as opposed to a dizzy because you will find the dizzy doesnt fit in the sierra engine bay. The sump will have to be modified and transferred from the sierra, you will also have to modify the vitara pickup as the sierra sump is much deeper. If you dont change the sump you will end up hitting it with your diff. Buy a BenT adaptor kit from ebay & you will get some very detailed instructions |
| Author: | BlueSuzy [ Thu Apr 15, 2010 1:51 pm ] |
And there is alot more with searching. All on the Baleno conversion http://www.outerlimits4x4.com/phpBB2/ft ... ght=baleno |
| Author: | Mullett [ Thu Apr 15, 2010 3:30 pm ] |
Having just done this, the coilpack option is a much easier one. Mine's running with a dizzy baleno motor, but I had to cannibalise the baleno and old vitara dizzy, along with using a vitara cam and dizzy bracket. A lot more hassle than it's worth...get a later model motor, or a proper vitara one -RM |
