https://auszookers.com/forum/
gti mk3 ecu trouble
https://auszookers.com/forum/viewtopic.php?f=5&t=11171
Author:  usher44 [ Fri Apr 16, 2010 1:38 am ]
Post subject:  gti mk3 ecu trouble
hey guys,
ive put a gti mk3 engine in a sierra for a mate and im having trouble with the ecu.
for some reason i have a vary faint inconsistant injection pulse.
i am fairly confident with all my wiring and everything the ecu needs seems to be there eg
b+
ignition feeds
earths
crank angle sensor
spark ignition input
starter feed
tps
afm
all other sensors ect.
all these things can be tested indiviually and seem fine.
injectors, fuel pressure, spark and compression are all good.
engine some times almosts fires while cranking and can be started up using aro start but stall strait away.
the guy who sold us the parts said it was running fine but the ecu is chipped
does anybody run a gti mk3 or has anybody ever had trouble like this?
cheers chris.
Author:  cbzook [ Fri Apr 16, 2010 3:17 am ]
Post subject:  Re: gti mk3 ecu trouble
mate, jump onto www.redlinegti.com post it in the tech bit, the guys on there are usually spot on with this kind of stuff, i had similar problems with mine, but mine was a vacum leak
Author:  unique_seek [ Fri Apr 16, 2010 6:02 pm ]
mate redlinegti is the go..have you checked you 12+??I am running an aftermarket ecu on my gti engine,but had similar problem with a bad earth to the ecu.make sure your getting power to all the necessary components/sensors and the ecu(make sure the ecu gets 12+ direct from the battery via a relay)..
Jono
