It is currently Sun Oct 25, 2026 5:25 am
Post Posted: Mon Apr 19, 2010 3:54 am
hey all,
ever sense i put the 2 inch lift in efs i have noticed that i dnt really have much flex to wat i had when i had tha stocko springs in i run pro comp shocks. Wat would be the easiest and cheapest way to fix this problem. would it be the springs or could my shocks be farked cos i can take my rear shocks out and they seem fine???
2''lift 31's twin locked & 6.5s
Post Posted: Mon Apr 19, 2010 4:12 am
Are your shocks long enough and if they are maybe remove a leaf or 2.
TWIN LOCK IT & JUST DRIVE!
Post Posted: Mon Apr 19, 2010 4:24 am
yeah prolly remove a leaf - when you open the pack there should be one leaf thats mega arched, usually 1 or 2 up from teh bottom... take that one out as its the load leaf.
downside is you're going to lose that 2" of lift...
Post Posted: Mon Apr 19, 2010 4:36 am
i thought the load leaf was the thick flat one on the bottom of the pack???
Vehicle: 89 Softtop Sierra, 6.5's, 30's
Post Posted: Mon Apr 19, 2010 4:47 am
So did I...it's basically flat and really thick, would make sense if it was the load leaf
Post Posted: Mon Apr 19, 2010 11:06 am
The very last one from memory is the one you want to remove... You loose about 1"0-15mm in ride height..
But becomes much nicer to ride in... Well much nicer compared to the current ride
Post Posted: Mon Apr 19, 2010 11:39 am
I was told by a good suspension shop that its the leaf just above the load leaf (ie: the leaf second from the bottom) that you want to remove. The load leaf is pretty much flat and doesn't do anything until either you hit a big bump at high speed or load the car up...
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Mon Apr 19, 2010 1:46 pm
sorry my mistake - i just always called the archiest one near the middle of the pack the load leaf.... either way - its the leaf one or two up from the bottom that has the biggest arc in it that you want to take out.
Post Posted: Mon Apr 19, 2010 9:49 pm
OK cos the very bottom one is out the flat one, and the shocks that are in there are the ones that i had in it when i had the spoa in it.
Post Posted: Mon Apr 19, 2010 9:51 pm
my shock do seem a lil hard to push down bar how hard is to hard ???
Post Posted: Tue Apr 20, 2010 1:09 am
Has it affected the drivability of the zuk , if not leave it alone and get used to driving with the current setup , it will soften up and work better and you will still maintain your lift which is why you put them in the first place , the more bend in the spring , the less travel you will have , flatter springs will travel more as they flex both ways , Cheers Paul.
Post Posted: Tue Apr 20, 2010 1:28 am
not really just lifts the wheels off more offen now. i did get them second hand.
Post Posted: Tue Apr 20, 2010 1:39 am
just run 3 leaves front and rear.
the top 3. that is all i run.
how old are they? were they quite used ? or fairly new?
Post Posted: Tue Apr 20, 2010 1:50 am
used i think and they got the dame zook lean on the drivers side
Post Posted: Tue Apr 20, 2010 1:53 am
i got the fronts off of zuki when he did ruf.so i knw they were used not to sure on the rears dont know how much use they got
Users browsing this forum: No registered users and 175 guests
