It is currently Mon Oct 26, 2026 1:54 am
Post Posted: Fri Apr 30, 2010 10:28 am
having trouble getting a panel shop willing to make up the amount and colour Im chasing to do a bit of a over spray of the bonnet and mud gaurds,,all seems to hard for them or they just couldnt be bothered..its a stock 89 zook. Im chasing only 1lt.what are the chances of getting hold of 5 or 6 touch up cans from a suzuki dealer, I have the colour code from the comp plate.or have I missed the boat..just asking before I ring around ,anyone else had luck matching old paint from a spray can. thanks
Post Posted: Fri Apr 30, 2010 10:39 am
Your best bet would be a paint supplies place. They will
mix whatever you want. Paint codes might help. The one went to mixed off a code as a starting point then tinted accordingly to match the age/fade of the paint. Basically done it by eye. Got it pretty close also
Post Posted: Fri Apr 30, 2010 11:04 am
best to go to a automotive paint shop and give them the code, they are very accurate as they go by weight, pretty sure they could make the colour you need as long as u got codes. it will be good to get a bit more then you need incase u need to touch some thing up later on
Post Posted: Fri Apr 30, 2010 11:13 am
thanks for the info..will do a bit of leg work on monday,thought id ask first.the spray guys around here just shrug me off..
Post Posted: Fri Apr 30, 2010 11:22 am
going to a paint shop and doing it urself is a way cheaper option, the spray people charge you a bucket full
Post Posted: Fri Apr 30, 2010 11:58 am
don't expect any paint to match unless it is mixed by someone who really knows
how to color match. it is hard for a puter to compensate for 21 years of sunlight. :wink:
Post Posted: Fri Apr 30, 2010 12:05 pm
not to worried close enough is good enough..its the metalic greenish blue.Im sure you have all seen it
Post Posted: Fri Apr 30, 2010 9:54 pm
I have exactly the same but on a tin top... my bonnet and roof have all faded :(
Post Posted: Sat May 01, 2010 11:47 am
A lot of paint suppliers have a device callled a spectro, it actually scans the paint and gets the closest colour available. its pretty accurate so thats the way i'd head, failing that any decent colour matcher will get it close.
Users browsing this forum: Google [Bot] and 209 guests
