It is currently Sun Oct 25, 2026 6:45 am
Post Posted: Fri Apr 30, 2010 1:10 pm
What are you guys using for flexible snorkle pipe, and where can ya get it from?
Dont need much, just enough to connect the snorkle up to the air box inside the guard.
Go Hard, Trailer Home
Post Posted: Fri Apr 30, 2010 1:18 pm
Use a silicone bend. You can buy them at autobarn or supercheap.
Flexable piping is obviously ribbed and as such will rob all of the benificial airspeed by causing air turbulance, negating the addition of a snorkel.
Post Posted: Fri Apr 30, 2010 1:25 pm
that stuff supplied with ataris snorkel was ribbed on the outside, and smooth on the inside
Vehicle: Jeep
Post Posted: Fri Apr 30, 2010 5:42 pm
Actually, yes and no on the turbulence inside the ribbed flexible Aluminium pipe... i used to do Air Con work, and the flexible ducting was ribbed, but it was spiral ribbed, and for a reason, it could actually help the air move through the ducting with reduced turbulence and resistance...
So if the ribbed flexible Alum pipe, is spiral ribbed, the better the air can move through it, due to the spiraling air pattern inside... sharp bends in pipes, like a 45 degree bend, would have more resistance and disrupt airflow... a gradual bend with the flexible pipe, would have less turbulence and air resistance... ok thats my 2c worth... lol... :wink: :lol:
Post Posted: Fri Apr 30, 2010 8:28 pm
I used a 3' to 2.5' 90 degree silicon reducer bend. Got it from these guys
http://www.enthaily.com.au/
Not sure how the Vits are set up though. Hope that helps
Post Posted: Fri Apr 30, 2010 9:03 pm
i used a big radiator hose.
Users browsing this forum: No registered users and 143 guests
