https://auszookers.com/forum/
bead leaks
https://auszookers.com/forum/viewtopic.php?f=5&t=11935
Author:  mudzookacoatsy [ Mon May 17, 2010 10:31 am ]
Post subject:  bead leaks
hello all,
the last few time i have been wheeling i have been getting bead leaks when doing sum tracks( i.e wombat hole at ripely) when my Tyre rubs up and the side of the dirt wall and the dirt gets stuck in there. i have 15x8 and 30-9.50-15 on there and r triangle AT. could it be becos the side wall is to stiff and they don't bag out enuf??? and i didnt air down any off these times if thats any help i run 25psi
Author:  Red89 [ Mon May 17, 2010 11:12 am ]
Post subject:  Re: bead leaks
Personally 8 inch rims are too wide for 9.5 inch tyre and wont be helping your cause.
Author:  Joe [ Mon May 17, 2010 11:37 am ]
x2 are you taking about the CSA alloys that are on the zook in your avatar pic cause im pretty sure they are 15x7s
Author:  alien [ Mon May 17, 2010 1:52 pm ]
i've had the same issue with my simex tyres (31s on 15x7's) - tubes fixed it... cheaper than beadlocks and still legal =) still have to be careful though.
Author:  banga [ Mon May 17, 2010 6:34 pm ]
i got this problem alot on my subaru when i was running winter treads i could never air down cause they were so soft. but when i got my bfgs it was better but my bfgs have that gay 'rim protector' on them which cause mud to get in there at anything under 18psi which is gay cause could never get full potential out of them
Author:  mudzookacoatsy [ Tue May 18, 2010 10:53 am ]
no the rims a 8'' might try the tube idea might work see how i go with new tyre
Author:  lordfury007 [ Tue May 18, 2010 8:21 pm ]
mudzookacoatsy wrote:
hello all,
Slightly off topic, but when you air down tyres you don't want the sidewall bagging out if you can help it, you want the tyre to increase along the tread...
Sidewall on the ground will damage and destroy your tyres - the sidewall doesn't have anywhere near the same amount of puncture resistance, and its also illegal to do a puncture repair on the sidewall of the tyre.
Author:  mudzookacoatsy [ Thu May 20, 2010 7:04 am ]
yeh i knw that i work at a tyre shop..
Author:  Fatzook [ Thu May 20, 2010 7:37 am ]
have the tyres removed. Clean the bead on the tyre and rim and then have re-fitted with a bead of sikaflex around the tyre bead. It makes a massive difference.
JMO
Pete
Author:  steak_knife [ Thu May 20, 2010 10:25 am ]
JMO
Pete
I'd hate to be the poor bugger trying to remover those tyre's tho..
You can get bead glue, not quite as permanent as Sikaflex
Author:  eldo [ Thu May 20, 2010 10:28 am ]
most factory tyres on quads come with bead glue, bloody hard to get them off, but they run 2-5psi all day with that stuff and you never lose a tyre off the bead
Author:  mudzookacoatsy [ Mon May 24, 2010 11:04 am ]
ok well do. so dont bother about the tubes? and im wanting to get sum muddies soon do i just say with the 30's or go to 31's . i will be putting gears in hopefully soon.
Author:  joeblow [ Mon May 24, 2010 11:09 am ]
chuck tubes in them. we all run tubes.....even our engineer wants us to run tubes. they work a treat.
Author:  mudzookacoatsy [ Mon May 24, 2010 11:22 am ]
oh ok so they go ok when u air down as well
Author:  joeblow [ Mon May 24, 2010 11:23 am ]
never had any issues.
Author:  kenn [ Mon May 24, 2010 12:13 pm ]
You work at a tyre shop and your asking us! :? Shouldn't it be the other way around.. :wink:
Author:  zuki [ Mon May 24, 2010 10:21 pm ]
Didn't someone say this on the w/end
x2 LoL
Author:  steak_knife [ Tue May 25, 2010 7:25 am ]
Apparently liquid nail's doesn't work.
Took a tyre off today that was flat & had the stuff around a dent in the rim. :roll:
