It is currently Wed Nov 04, 2026 11:02 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
Post Posted: Tue Jul 24, 2007 8:28 pm
Was working with a friend of mine the other day, and he was a fellow zooker. he has a 4AGZE corolla engine in his. [i think thats what he said]. it was a 1.6 fuel injected twin cam with a five speed. i was curious, seeing the corolla's are renown for reliability, and asked how much he though it would be to fit into mine. he told me it was $1500 for a 'half cut'. he said that included the gearbox. now the word 'half cut' implies there being more parts to buy.... am i right? and does anyone know of a website where you can buy 4AGZE engines and gearboxes so i can check prices?
Post Posted: Tue Jul 24, 2007 8:55 pm
$1500 is pretty good for a RWD halfcut
things that suck about the conversion
tis a toyota engine
they are heavy so ruins the handling
its a toyota engine
the gearbox is longer so the engine site forward
its a toyota engine
nothign really lines up and they always end up a messy converstion
its a toyota engine
you have lots of customparts that are hard to replace in the middle of nowhere
its a toyota engine
toyotas arent reliable, toyota jsut spend lots of money telling you that :wink:
Post Posted: Tue Jul 24, 2007 11:59 pm
a half cut is normally a car from japan. That before they exported it to aust it was cut in half. so ya still normally get the steats dash engine wireing loom etc.
[IMG]http://img.photobucket.com/albums/v711/richmo
Post Posted: Wed Jul 25, 2007 12:52 am
so its easier to go with the vitara 1.6?
Post Posted: Wed Jul 25, 2007 12:55 am
Yes by a long way mate. JMO :-)
Post Posted: Wed Jul 25, 2007 1:08 am
actually its easier to just buy a vitara, lots of little things make even a 1.6 a drama in a 1 litre sierra
Post Posted: Wed Jul 25, 2007 9:40 pm
its a toyota engine:wink:
did u mention that its a Toyota engine??? 8O
[img]http://www.auszookers.com/modules/coppermine/
Post Posted: Wed Jul 25, 2007 10:17 pm
I have heard toyota may have something to do with them :wink:
Post Posted: Wed Jul 25, 2007 11:28 pm
Isn't the 4agze the supercharged model , is that want you want , Cheers Paul.
Vehicle: No Zook For You
Post Posted: Sun Jul 29, 2007 4:32 am
iv been told that the 4agze is supercharged injected. The 4age is just injected and the 4ag is the carby version. something also mean twin cam and single but i dont know?
One Life, One Search
Post Posted: Sun Jul 29, 2007 9:58 pm
maybe try asking on a toyota forum. I've seen a toyota engine conversion and a gti conversion, if its speed you want the gti hammered along. :twisted:
Post Posted: Sun Jul 29, 2007 11:18 pm
its a toyota engine
toyotas arent reliable, toyota just spend lots of money telling you that :wink:
Hey Royce, my last car was a Toyota Corolla Seca 85 model with 1600. 354,000 km when I traded her in after buying her almost new and never did any work to the engine! Only just started to have a small oil leak towards the end. I did all the services myself and used nothing but the best oil.
Yeh, I'd say reliable :D
Zooks Rule
2005 Jimny Z Series with VVT
[img]h
Post Posted: Mon Jul 30, 2007 12:30 am
pfft for every good toyota story I hear I have 7 bad ones
Bet you never replaced a wheel bearing, stupid stupid design :roll:
Post Posted: Mon Jul 30, 2007 1:20 am
ok.... it seems most people have a bone to pick with every engine mod possible. SO, for the easiest cheapest more powerful/torque conversion, tell us you preference
Post Posted: Mon Jul 30, 2007 4:16 am
ill be going GTI but not for a long time...
Post Posted: Mon Jul 30, 2007 12:47 pm
do you want easiest, chepest or most powerful?
easiest, Maruti 1 litre
cheapest, good second hand 1 litre
most powerful, one of the engines out of the bandag bullet
being a 1 litre sierra makes it a tad more difficult cause the trans tunnel is narrower and there is less bonnet room
good compromise is a 1.6 from a vitara and a 5speed from a 1.3 sierra, a bodylift should solve the bonnet and tunnel clearence and if you cut the mounts and gearbox crossmemeber from a 1.3 sierra you should be able to get it all back in so it looks OK
Post Posted: Fri Aug 03, 2007 4:28 am
My advice, take it all leave it is to go with the 1600 conversion. i have personaly had it done recently i might add,and love the power/ torque increase. It wasn't in the shop for very long. They get an adaptor plate so it just bolts straight in. with just a couple of washers on the engine mounts. Im running 32's with series 3 rockhoppers and i can cruze at 100kmph quite easily. However it revs very high but that because i have the rockhoppers. She uses a little more fuel at those speeds. If you want you can getthe fuel injection to. My suggstion is get it all at once save you some dollers in the long run. My mistake. I didnt do that and its goen to cost a little bit now. If you can afford it go the 1600 with the 16valve efi. thats the top notch. If not do what i did a reco 1600 and save by using your old carby. Use your head to a bump up the compression. Just my advice use it or not. Do your research!!!!!!!!!!!!!!!!! Happy zooking.
Post Posted: Tue Aug 14, 2007 2:33 pm
hay mate iv got a 4AGE 16v in my zook its a lot of work. Things allwas brak but it gos qik. when i got it on dino it put out 119kws. its good but not reliable
Post Posted: Thu Mar 10, 2011 6:34 pm
Sorry to grave-dig, but I want to know more about 4agze+sierra=
-Can a fwd motor be used?
-What is the block made of?
Vehicle: Daisy
Post Posted: Thu Mar 10, 2011 7:15 pm
I was seriously considering this conversion as my engine was smoking like a chimney and after all the research it was the cost that put me off.
You "can" use a fwd motor but it's a bit of work to convert it to fit, if it's just a 4age it's the intake manifold having to be cut and shut and possibly some other stuff (water piping) needing extra work. Along with needing to find a T50 box, OR a W box with an adapter bellhousing (expensive, as in $500 for box and $500 for adapter, It may be more, I was looking at getting a T50 and they are around $400 if you can find one)
I am not 100% sure about converting a fwd 4agze, however I think the 4agze are ALL fwd so I'm sure it can be done, but it will be more work again.
IF you can find a rwd 4age, it would be the easiest conversion of the 4age types I think because you already start with a rwd setup motor, there is still a lot of fab work to be done, but at least you're not stuffing around cutting and shutting intake manifolds and re-routing water pipes e.t.c.
Now for the bit that put me off. These are the prices I remember off the top of my head, I did the research in January so not that long ago but may have changed or I may have remembered a bit off. These were wreckers prices and average second hand private sale, you might get cheaper. The motors were all "run tested" but you could still get a bad one and be rebuilding after a short time.
IIRC:
T50 = $400
Wbox+Adapter = $1000
4age bare motor RWD (still needs ecu + loom) = $1300-1600
4age ecu + loom = $300
4age silvertop halfcut (fwd) = $2500
4age blacktop halfcut (fwd) = $3000
4agze halfcut (fwd) = $3500
Then you need to think about other costs once you have it and go to put it in.
These include:
Custom clutch setup - as the toyota stuff is hydraulic and your stock sierra is cable.
Radiator - pretty sure you need to recore the 1.3 or put in one from a 1.6L.
Engine mounts - if you are good at fabwork (which you need to be for a cheaper conversion) they won't be too much trouble.
Moving Transfer case - The toyota box is longer and you NEED to move your transfer case to do the conversion properly.
Custom Shafts - You had to move your transfer case so depending on how far, you may need to change the Jackshaft, and Front and Rear tailshafts.
Shifter hole - you just moved your transfer and part of that is cutting a bigger hole for the shifter. Depending on the gearbox you may have the same issue with that, I didn't get that far when I was looking at it.
Oils and fluids - When you're changing an engine you have to replace them and the costs soon add up.
Mod Plate - couple of hundred dollars for this, get the engineer on side BEFORE you start the conversion.
Insurance - I've heard of people having trouble even with the vit 1.6. In a sierra, I can't find this to confirm.
Upgrades - now that you have at a minimum double the power and torque of the stock engine, you have a good chance of breaking things so you need to look at this as well, I won't go into it now, post is huge already.
Maintenance - You have a lot of non standard parts now, what happens when they break.
To answer your second question, I'm pretty sure they are an alloy block, Ideally you want a 7 rib block (stronger) but unless you're chasing huge amounts of power you don't really need to worry about it.
I had decided on getting a RWD redtop 4age if I was going to do the conversion, while it would be awesome to put a 4agze in, I couldn't justify the cost increase and extra work to fit it and maintain it.
Good luck with it, you NEED to be handy on the tools and at fabricating (or know someone who will help you who is) and you'll still need to farm some stuff out unless you own or have good access to a machine shop and the skills to do what's needed. Again, in the end I chose not to do this due to COST rather than anything else, but it will take a LOT of time and effort to do correctly.
Post Posted: Thu Mar 10, 2011 7:37 pm
GZE is cast steel block. Only the GZE has the extra webbibgs on the block. It also has more internal oil ports for better lubrication.
4AGZE front cuts can be had for $2500 or less over here. ( maybe less in UNZUD) but you will need the T50 box AND!!!! its bottom support brackets!!! Most people forget these and wonder why they have shaft play in their gearbox after only a few months.
I reckon you should find an early vitara G16a TBI motor and fit that. Great engine and easy to find in NZ.
Post Posted: Thu Mar 10, 2011 7:49 pm
4agze for sale
I want more power than a G16a can give me. Plus I don't want head cracking problems. Does a T50 box bolt on to the 4agze or is it harder than that?
Post Posted: Thu Mar 10, 2011 10:29 pm
go a rotor problem fixed
light weight
need fixing every 3 months
heaps of room
broken driveline
josh AKA Bazook
Post Posted: Thu Mar 10, 2011 10:32 pm
what does a g16 weigh?
info i can find on the 4agze is that is around the 88 kilo mark.
maybe j20??
Post Posted: Thu Mar 10, 2011 10:48 pm
maybe j20??
Yeah, I would apart from the fact that they are rare as rockin horse s**t in N.Z. :cry:
Post Posted: Thu Mar 10, 2011 10:53 pm
h20? h25 or h27?
j18 , j24. heaps of awesome suzuki motors :D
Post Posted: Thu Mar 10, 2011 10:57 pm
What a load of.....
I was racing a PRB Clubman with a 16v 4AGE in it - and have had quite a lot to do with those with the 20v 4AGE engines in them. Their a very reliable engine. The 4agze however puts out lots of heat and I'd prefer a NA 20v any day.
Wouldn't put one on a zook though, As already mentioned it never works well and is a dog of a conversion. You'd be better served with another Zook engine as a replacement.
Vehicle: 03 Jimny
Post Posted: Thu Mar 10, 2011 11:46 pm
zukmeista wrote:
4agze for sale
Can I ask why you would want power in a 4wd
Wouldn't you want torque not power
I have a g16a with a g13ba head on it
Very low compression
Stock gearing
Can fly up hills in 5th
I can even overtake cars on a hill :)
I can wind my Sierra up to 130kph on flat straight on 29/30 tyres
It's bloody scary
I don't understand why u would want more power then a g16a
Just my 2c
Post Posted: Thu Mar 10, 2011 11:56 pm
zooky08 wrote:
[I have a g16a with a g13ba head on it
Stock gearing
It's bloody scary
Just my 2c
I can do all that with my 1.3 :lol:
Post Posted: Thu Mar 10, 2011 11:58 pm
I was doing the 4AGE converision, pretty much need to change EVERYTHING!
if i was to have my time over again, i would spend alot of time reading on other peoples mistakes and achieved goals before i would have started my build. i would have ended up going with a EFI Vit engine.
i believe the Corolla engines are strong and reliable, with the 4 or 5 that i have known / dealt with, i have nothing but good things to say about them.
i just believe it would be much easier to go a tried and tested solution instead of cracking your engine conversion cherry on something tough like the 4AGE conversion.
FYI.... any 4A series motor will have the same gearbox stud pattern.
84 model corolla's come with a T50 5 speed in them... and the whole corollas can be found pretty easily. the autos can be found just as easily.
toyota sprinters came out with a RWD 4AGE bigport in them.... just a suggestion if you want to save heart ache.
but the best thing as i stated earlier is to search and see other peoples problems they encountered.
good luck whichever way you go.
just remember, there are a lot of unfinished projects out there... you dont want to add one to the list.
Web wheeler extroadinaire
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 239 guests
