It is currently Sun Oct 18, 2026 10:36 pm
Post Posted: Thu Jun 04, 2020 5:58 pm
Anyone experienced this before??
In the wet weather last week I was having some slippy fun times with the locker on. Disengaged it before reversing up my driveway, and then the other day went for a spin and it's still locked.
I have:
- Undone the solenoid
- Cleaned the brass filter
- Turned it off and on MANY times
- Undone both fittings on the diff in case there's a blockage there (there wasn't)
- Done all sorts of figure 8's and throttle blips
Any ideas how to get it to unlock??? lol
Post Posted: Thu Jun 04, 2020 11:23 pm
Have you tried jacking the car off the ground? If there's any wind up on the axle the locker might bind and not move until the stress is released.
Post Posted: Fri Jun 05, 2020 6:26 am
Never even crossed my mind - I'll give it a crack and report back =)
Post Posted: Fri Jun 05, 2020 8:01 am
No effect... Went back and forth a bunch, jolting it and moving it gently and still locked.
Vehicle: SJ80, SE416
Post Posted: Wed Jun 10, 2020 3:55 pm
Older style locker - broken tabs on the plastic piston inside the locker?
Post Posted: Wed Jun 10, 2020 7:22 pm
This 100%, happened to mine. Permanently locked on when it happened.
Post Posted: Wed Jun 10, 2020 8:17 pm
Booooo.. Maybe
Advice I've been given from an ARB fitter is to try blow out the metal tube in the housing and see if that frees it up as it might be full of oil... He's seen that happen a bit apparently.
Assuming if it's the plastic tabs, the whole centre has to come out?
Post Posted: Wed Jun 10, 2020 9:26 pm
Yes, diff out. Not even sure if you can still get the piston
Post Posted: Thu Jun 11, 2020 7:56 am
had it happen a few times, we looked at making alloy pistons to replace
Post Posted: Thu Jun 11, 2020 12:44 pm
@tanshi - did you ever do it?
The plastic ones are still available according to ARB, but if I can future-proof it with alloy that'd be awesome.
Though, the current rear locker is from 2008 so it has done rather well haha
Post Posted: Thu Jun 11, 2020 1:49 pm
nah we never finished it. they would be friken expensive to make from billet.
Post Posted: Thu Jun 11, 2020 7:53 pm
Oh right, yeah I suppose that'd be the only way??! it'll be interesting if the replacement plastic part is made any differently to the old one.
Users browsing this forum: No registered users and 248 guests
