It is currently Tue Jul 28, 2026 11:46 am
Post Posted: Fri May 28, 2010 11:05 pm
Fitting a winch to the GV 2002 SWB
Picked up a second hand alloy bullbar this week and have a little Aldi winch
Now the problem starts where how do I fit it??? The bar dosnt have a cut out but the 4" grinder can fix that. Do I need to make a mount plate to fix to the chassis.
Post Posted: Fri May 28, 2010 11:28 pm
Most defiantly, if you see ANY wire's that have a YELLOW sheath or plug, don't f*#k with then.
Thay are your air bag sensor's & harness, if you damage or cut the harness you WILL need to replace the harness, big poo poo if you repair a SRS harness.
Users browsing this forum: No registered users and 380 guests
