It is currently Tue Oct 27, 2026 10:40 am
Post Posted: Sat May 29, 2010 6:06 am
Was curious about the ability of flipping a sierra standard rim. I worked out that you can do it, it gives you 44mm extra on maximum offset, and looks pretty stock-ish. and looks tough on WT diffs and no flairs. I spent a while truing it (within 2mm), but decided that ill take it to a shop to get it 100% trued.
:D
Post Posted: Sat May 29, 2010 6:56 am
Looks good buddy :P Are ya gunna change the tyre valve over or just leave it on the inside????
Post Posted: Sat May 29, 2010 6:59 am
x 2
looks good but that would suck balls airing up/down...
Vehicle: nt sierra
Post Posted: Sat May 29, 2010 7:30 am
why not drill a hole on the outside and fit a new valve?
nothing says you cant have two.
Post Posted: Sat May 29, 2010 7:39 am
Looks good. I have a jig for trueing wheels. Shame you live so far away :(
Vehicle: Sierra
Post Posted: Sat May 29, 2010 8:43 am
got a pic fitted to zook?
Vehicle: jimny
Post Posted: Sat May 29, 2010 9:13 am
Good work Josh, now make me some
Post Posted: Sat May 29, 2010 2:35 pm
i got a old set of 7" sunnys flipped for my lux years back.they welded up the valve hole and drilled a new one one the outside now.Works a treat
good work mate.if ya took the tyre off,could get it pretty good using a straight edge across the rim yeh???Fatzook,hows your jig look?
Post Posted: Sat May 29, 2010 10:20 pm
thanks joe, and atari ill be pluging the air hole on the inside and drilling a new one. 86slowsierra, one of them would leak for sure... :( mika yes i did mount it but i didn't get a chance to take a photo of it.
appsie, im not sure if this is dodge, but i stuck the rim on the rear of my lwb and clamped a cold chisle to it and spun till there was about 2mm difference then couldn't get it the last little bit. I think thats as accurate as im going to get it without a jig. Fatzook has a pm...
luke ill do it if you supply the rims and bring them down.... :D
Vehicle: jimny
Post Posted: Sun May 30, 2010 11:37 am
josh you should do a tech write up on how you did it, would maybe inspire me to have a go myself
Post Posted: Sun May 30, 2010 2:58 pm
Car 726 has run those rims reversed for years, his are powdercoated silver, they look great.
Post Posted: Mon May 31, 2010 6:26 am
yeah i was going a pressure pack silver or champagne if i can...
luke, all you need to do to get them apart, is very very carefully grind the welds out then i just hit it with a lump of wood and a 4lb hammer till it pressed out.... not allot else to it...
Vehicle: 93 Sierra
Post Posted: Mon May 31, 2010 6:46 am
Just a reminder to take the tyre off the rim if you're going to try welding it into position...
http://www.youtube.com/watch?v=jBUVzgCH ... r_embedded
Post Posted: Mon May 31, 2010 7:02 am
yes i shall thanks tim.
Vehicle: 93 Sierra
Post Posted: Mon May 31, 2010 7:37 am
Just thought I'd stick it in there for the next person to search "flip rims" ;)
Looks great BTW ... now just need a nice skinny 31" tyre that'll fit it without rolling off the bead constantly. What are you thinking about fitting to it?
Post Posted: Mon May 31, 2010 6:57 pm
30x9.5 is where it's at ;)
Users browsing this forum: No registered users and 166 guests
