It is currently Sun Oct 25, 2026 7:58 pm
Post Posted: Sat Jun 05, 2010 4:20 am
Has anyone experienced wipers that do not park ? - also intermitant not working ? - Any ideas
It's a SWB 88 Vitara... I have a new wiper motor too, and both new and old have the same issue .... they just stop wherever you flick the switch - also I think when you pull the lever for washer the wipers are ment to go on ??/ -well they don't --- so whats broken ?
Post Posted: Sat Jun 05, 2010 4:22 am
The switch inside where the lever connects.
Post Posted: Sat Jun 05, 2010 4:39 am
do you mean inside the actual switch mechanism ???? - any more details ????
Post Posted: Sat Jun 05, 2010 4:51 am
No, sorry, just that a friend has just had the same thing happen, and its non serviceable and needs replacing
Post Posted: Sat Jun 05, 2010 6:00 am
i had the exact same thing happen on my patrol. I replaced the switch the motor and the amp but it did not fix it. It ended up being a faulty wire going to the motor. i found it by removing the wires from the clip in the wiper motor one at a time untill the problem stopped. if i removed the wire and it didnt fix it i plugged it back in. when i found the right cable i re ran it from the switch. tedious i know but i hope this helps.
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Post Posted: Sat Jun 05, 2010 6:52 am
you will need the switch mate..
which is the como switch... includes lighting/indicator and wiper stalks all in one.
that (without looking at the vehicle) will fix your problem
Users browsing this forum: Google [Bot] and 109 guests
