| tail lights for mounting flush in rear door?? https://auszookers.com/forum/viewtopic.php?f=5&t=12521 |
| Author: | appsie [ Sun Jun 06, 2010 9:25 am ] |
| Post subject: | tail lights for mounting flush in rear door?? |
just after some info on where people are buying lights like in the back of rhetts zuk truggy,dans vit etc.or like the ones i just posted in brodies member page? Have seen em once at a local truck place,just wondering if there are any cheaper places? |
| Author: | steak_knife [ Sun Jun 06, 2010 9:27 am ] |
| Post subject: | Re: tail lights for mounting flush in rear door?? |
www.eziautoparts.com.au Have a flick through, I found some good one's in the trailer section.. |
| Author: | bails [ Sun Jun 06, 2010 9:38 am ] |
try these lot http://www.ledautolamps.com/ they are ebay as well. |
| Author: | appsie [ Sun Jun 06, 2010 9:51 am ] |
thanks fellas,had a bit of a look in ebay aswell.will keep lookin round |
| Author: | 89_tintop [ Sun Jun 06, 2010 10:05 am ] |
there is some good shit on that sight steknig... well one thing http://www.eziautoparts.com.au/dial-tyr ... -case.html it looks like it ay be handy |
| Author: | sierra_666 [ Sun Jun 06, 2010 10:09 am ] |
i got led strip lights for $30 each at autobarn they just recess into tailgate |
| Author: | lump_a_charcoal [ Sun Jun 06, 2010 10:10 am ] |
Thought about putting them into the body itself? Timmay did it, looks OK... |
| Author: | steak_knife [ Sun Jun 06, 2010 10:10 am ] |
http://www.eziautoparts.com.au/klaxon-v ... -horn.html AAAAAHHHHHOOOOOOOGGGGGGAAAAAHHHHHHHHHH |
| Author: | 89_tintop [ Sun Jun 06, 2010 10:13 am ] |
steknig wrote: http://www.eziautoparts.com.au/klaxon-vintage-air-horn.html
AAAAAHHHHHOOOOOOOGGGGGGAAAAAHHHHHHHHHH i actually had an original flaxton horn... left it at a shop i used to work at... i recoed it.. was a ball to play with |
| Author: | Gwagensteve [ Sun Jun 06, 2010 10:23 am ] |
Just ensure lights you are planning to use have the appropriate approval. Whilst it might not be the most illegal thing about you car, it's silly to get a defect for using a marker light (or similar) as an indicator or stop/tail light. Most of the LED autolamp lights are marked as to what position/ orientation they are legal in. Steve. |
| Author: | appsie [ Sun Jun 06, 2010 10:36 am ] |
yeh too easy steve.thanks.i will only buy something approved and right for the job if not ill just make a new rear bar and use my existing sierra ones,something like bogfrogs zook is getting. yeah lump a....... i like how timmy has his and bails lwb has them sunk in like that also but my rear corners are a bit squashed out of shape and wouldnt make it a easy job. My main problem is i dunno if i want a tube bar,a rhs bar that looks like stock but can mount a swing away.So ill have to way it up,if i went tube rear id gain some clearance but would sink lights into doors then i cant run a spare carrier or make a stock looking stronger rear bar and mount lights in it,then i can run a swing away if i want and get some space back inside???? |
| Author: | lukes_89 [ Sun Jun 06, 2010 10:45 am ] |
just so you know led lights on the rear door=non road worthy as its a swinging panel |
| Author: | steak_knife [ Sun Jun 06, 2010 10:49 am ] |
lukes_89 wrote: just so you know led lights on the rear door=non road worthy as its a swinging panel
so weld it closed.. i forgot about that rule. |
| Author: | appsie [ Sun Jun 06, 2010 10:54 am ] |
fair enough then.Id be happy enough to build em into a bar i think.Its only steel,just drag that shit |
| Author: | BlueSuzy [ Sun Jun 06, 2010 10:54 am ] |
lump_a_charcoal wrote: Thought about putting them into the body itself?
Timmay did it, looks OK... Yeah i'm unsure what i want to do with my Lwb. Same? and swap tailgates? |
| Author: | lump_a_charcoal [ Sun Jun 06, 2010 10:58 am ] |
No. Make a good swing away for suuuuuuuuuuuzy and mount lights in the bar. |
| Author: | appsie [ Sun Jun 06, 2010 11:00 am ] |
why do you say that?its a pretty sick looking rear end timmay has |
| Author: | lump_a_charcoal [ Sun Jun 06, 2010 11:10 am ] |
I reckon it suits suzy, but I think suuuuuuuuuuuzy needs a rear bar with a swing away. |
| Author: | BlueSuzy [ Sun Jun 06, 2010 11:12 am ] |
SuzyII or suuuuuuuuuuuzy i think i will put the tyre in the tub again. And still 4 seater. Yay! |
| Author: | steak_knife [ Sun Jun 06, 2010 11:16 am ] |
BlueSuzy wrote: SuzyII or suuuuuuuuuuuzy i think i will put the tyre in the tub again. And still 4 seater. Yay!
MMmmmmm, Lwb. |
| Author: | appsie [ Sun Jun 06, 2010 11:18 am ] |
all you damn lwb owners |
| Author: | BlueSuzy [ Sun Jun 06, 2010 11:23 am ] |
Mine were tricky, and very lucky. They were just the right size in the corners. Any bigger and it would of been an oh shit cover up nightmare. The tray door was a cover up also, dented, twisted etc. Bent it back, welded in boxes. Cover with plate! |
