| Exedy H/D Button clutch for sierra https://auszookers.com/forum/viewtopic.php?f=5&t=12627 |
| Author: | finlay113 [ Thu Jun 10, 2010 7:40 am ] |
| Post subject: | Exedy H/D Button clutch for sierra |
ordered a h/d button exedy clutch today for mky sierra. has anyone ever had one. how harsh are they? |
| Author: | oozuk [ Thu Jun 10, 2010 7:54 am ] |
| Post subject: | Re: Exedy H/D Button clutch for sierra |
ive got the exedy hd full plate clutch on my turbo'd 16v 1600 and it works great, a button clutch is too harsh for a sierra, what engine are you running to require this??? I'm running 135hp ATW's with 33's with no slip |
| Author: | finlay113 [ Thu Jun 10, 2010 7:58 am ] |
i just have a rebuilt 1.3 lol. spoa 33's, 6.5 transfer gears, currently looking for a 1.6. so i just bought the button and i can use it later wen i have the 1.6. |
| Author: | Ben_Sierra [ Thu Jun 10, 2010 7:59 am ] |
1.6 has nowhere near enough power to be worrying about a button clutch with 6.5s and 33s! |
| Author: | finlay113 [ Thu Jun 10, 2010 8:00 am ] |
i've been through 2 clutches already. in just a few months |
| Author: | Ben_Sierra [ Thu Jun 10, 2010 8:01 am ] |
Well they're either shit cheap clutches, incorrectly installed or poor driving... |
| Author: | buzbox [ Thu Jun 10, 2010 8:03 am ] |
A H/D clutch will be fine.. You might end up with a left leg like the Hulk, but you'll get use to it. The only problem, Is the colour.... It's umm a bit ghey.. |
| Author: | finlay113 [ Thu Jun 10, 2010 8:04 am ] |
im a mechanic, so not shit installs, how can u posably stuff up installing a clutch, and there exedy clutches, although i've only just put the transfer gears in so maybe the extra strain from the tyres and bad gearing is the cause |
| Author: | steak_knife [ Thu Jun 10, 2010 8:08 am ] |
finlay113 wrote: im a mechanic, so not shit installs, how can u posably stuff up installing a clutch, and there exedy clutches, although i've only just put the transfer gears in so maybe the extra strain from the tyres and bad gearing is the cause
Bingo!!!!! |
| Author: | finlay113 [ Thu Jun 10, 2010 8:11 am ] |
steknig wrote: finlay113 wrote: im a mechanic, so not shit installs, how can u posably stuff up installing a clutch, and there exedy clutches, although i've only just put the transfer gears in so maybe the extra strain from the tyres and bad gearing is the cause Bingo!!!!! i thought that might be the case, but i had the chance to get the button clutch cheap so i thought i may aswell give it a go |
| Author: | steak_knife [ Thu Jun 10, 2010 8:20 am ] |
It's worth a try, but i think you will find it annoying, thay are in or out, that's it, don't like to be slipped.. |
| Author: | finlay113 [ Thu Jun 10, 2010 8:21 am ] |
yeah i hardly drive it so it'll be right. ill just deal with it. |
| Author: | 2stroker [ Thu Jun 10, 2010 8:26 am ] |
finlay113 wrote: yeah i hardly drive it so it'll be right. ill just deal with it.
If that is the case your other clutches must have just been eaten by moths Button clutches are not designed for 4x4ing, far to harsh, they are on or off, you need to be able to feed in power to negotiate obstacles. Anyway it is done now so tell us how it goes. |
| Author: | finlay113 [ Thu Jun 10, 2010 8:29 am ] |
haha they dont get treated with much respect when we go out for a play, this one should last longer hopefully |
| Author: | LILBRT [ Thu Jun 10, 2010 8:32 am ] |
Is it spring button or cushion button or don't exedy make both? |
| Author: | finlay113 [ Thu Jun 10, 2010 8:34 am ] |
its a h/d spring button |
| Author: | steak_knife [ Thu Jun 10, 2010 9:09 am ] |
LILBRT wrote: Is it spring button or cushion button or don't exedy make both?
Love your avatar mate!!! |
| Author: | joeblow [ Thu Jun 10, 2010 9:12 am ] |
finlay113 wrote: im a mechanic, first clue. finlay113 wrote: although i've only just put the transfer gears in so maybe the extra strain from the tyres and bad gearing is the cause
mmmm.....i think you may be on to something there. i'd be beefing things up behind the 6.5's not infront. |
| Author: | steak_knife [ Thu Jun 10, 2010 9:16 am ] |
joeblow wrote: finlay113 wrote: im a mechanic, first clue. finlay113 wrote: although i've only just put the transfer gears in so maybe the extra strain from the tyres and bad gearing is the cause mmmm.....i think you may be on to something there. i'd be beefing things up behind the 6.5's not infront. What are you trying to say Joe?? |
| Author: | Gwagensteve [ Thu Jun 10, 2010 11:14 am ] |
Tall gearing/high load (that means big tyres with stock gearing) will murder clutches. I have a 1.0litre sized clutch (trust me, it's tiny) and a regularly clutch dump at over 6000rpm, sometimes on the limiter - 7500rpm with 35" tyres. At those revs I'm producing as much power and torque as a 1.3, at least. I have 6.5:1 transfer gears and 5.12 diffs. and I've never had clutch problems (until sunday, where I filled it with mud so badly it won't drive or engage at all) But a stock 1.0 with 30" tyres can destroy a clutch in a day. Now you are geared right the clutch should last fine. If it doesn't last, you've either filled it with mud or you are a hack driver. I don't mean aggressive - I'm really aggressive with my car when required - but if you're hack it's possible to destroy anything. Steve. |
| Author: | appsie [ Thu Jun 10, 2010 11:35 am ] |
i thought i remembered reading once before you were on 33s and no gearing,but now that you have that sorted you will find you are good to go . my zuk had a half worn out clutch when i went from 1.3 to the 1.6 efi but money and time was tight at the time so i put it in.I have 6.5s and 31s and it has never shown to be a problem since on road and expecially off.Once when i had to recover a vehicle it got a bit slippy though. Surely you wont wreck another one,can you do a swap on a normal HD tho? |
| Author: | finlay113 [ Thu Jun 10, 2010 11:47 am ] |
i've already ordered this clutch and put a deposit on it. so i may aswell give it a go and see wat its like. it turns up tomorrow and i'll put it in tomorrow night. as long as the boys dont come round and drink to much beer anyway. lol |
| Author: | Fatzook [ Thu Jun 10, 2010 11:49 am ] |
finlay113 wrote: i've already ordered this clutch and put a deposit on it. so i may aswell give it a go and see wat its like. it turns up tomorrow and i'll put it in tomorrow night. as long as the boys dont come round and drink to much beer anyway. lol
Have you had your flywheel machined already? |
| Author: | finlay113 [ Thu Jun 10, 2010 11:51 am ] |
yeah had it done today |
| Author: | Fatzook [ Thu Jun 10, 2010 11:52 am ] |
finlay113 wrote: yeah had it done today
What did they sting ya for that? My last flywheel machine cost me $7 |
| Author: | finlay113 [ Thu Jun 10, 2010 11:53 am ] |
damn it. mine was 30 lol. i got ripped haha |
| Author: | Fatzook [ Thu Jun 10, 2010 11:54 am ] |
finlay113 wrote: damn it. mine was 30 lol. i got ripped haha
Nar $30 is about right |
| Author: | finlay113 [ Thu Jun 10, 2010 11:56 am ] |
i thought so, same place we get all the ones at work done. |
| Author: | finlay113 [ Sat Jun 12, 2010 7:17 am ] |
clutch is in. went out today and the clutch is awesome. and so are the 6.5 gears. it goes nearly anywhere |
