It is currently Mon Oct 26, 2026 3:48 pm
Post Posted: Fri Jun 11, 2010 11:06 pm
I've started the process of fitting a Sierra steel diff casing into my Vitara front.
I will be using the stock alloy axle housing still, as to steel those, I have to steal those 8O
I'm told extra strapping of front diff mount will help avoid alloy diff casings exploding.
My main question is
will I need extra strapping down with the steel diff?
I have an empty 1.3 diff case/pinion housing, I will fit that in to work out the bracket I need to make, then pull it out, save for locker, then put all the vit diff and locker into the steel housing.
christover
Post Posted: Fri Jun 11, 2010 11:07 pm
If anyone has done this, I would value any input
Post Posted: Fri Jun 11, 2010 11:09 pm
you used to be able to get a collar from rocky road or somewhere that went around the sierra pinion area to mount to the crossmember, maybe copy that?
Post Posted: Fri Jun 11, 2010 11:31 pm
Yes I was planning something similar, just wasn't sure if needed.
Will look into that, though.
I will shove it in the hole and have a look see, sometime soon.
Post Posted: Fri Jun 11, 2010 11:40 pm
yeah you need that mount, it stops the diff twisting around
Vehicle: 98 Maruti
Post Posted: Fri Jun 11, 2010 11:52 pm
i found a picture of an American site where a bloke made a brace that attached to the bolts on the top of 3rd member and bolted to the driver side mount point, if i can find the picture il post it up
Post Posted: Fri Jun 11, 2010 11:58 pm
cheers all, it all helps
Post Posted: Sat Jun 12, 2010 12:31 am
I will be using the vitara carrier, as the steel diff is empty
(assuming it will fit)
I'm finding different part numbers for front lockers in Sierra and Vitara,
and I thought they be the same.
LOWRANGE sell a front lockrite with carrier already to go,
so that may be an option.
http://www.lowrangeoffroad.com/index.ph ... ystem.html
May still need to use Sierra carrier if lock rite type lockers are hard to get for Vit.
Post Posted: Sat Jun 12, 2010 5:09 am
they are different depending on the splines you have
Users browsing this forum: No registered users and 277 guests
