| removing rear wheel bearings https://auszookers.com/forum/viewtopic.php?f=5&t=12788 |
| Author: | mudzookacoatsy [ Wed Jun 16, 2010 8:09 am ] |
| Post subject: | removing rear wheel bearings |
hey all, Ive gotta replace my rear wheel bearing tomorrow at work. im wanting to know wats is the quickest way and easiest way to do it ? |
| Author: | Fatzook [ Wed Jun 16, 2010 8:10 am ] |
| Post subject: | Re: removing rear wheel bearings |
Grinder and chissel. Just don't cut into your axles. |
| Author: | mudzookacoatsy [ Wed Jun 16, 2010 8:14 am ] |
ok then kool so just cut them down enuf and then chissel it off.????? |
| Author: | Rhino [ Wed Jun 16, 2010 8:17 am ] |
Fatzook wrote: Grinder and chissel. Just don't cut into your axles.
NOTE you might like to wear safety glasses during this stage. They some times like to jump |
| Author: | Fatzook [ Wed Jun 16, 2010 8:19 am ] |
Yeah there is a bearing and a retaining ring. You cut through the retaining ring the best you can then smash it appart with a chissel. Then attack the bearing. As Rhino said, wear some safety gear. |
| Author: | Merk [ Wed Jun 16, 2010 8:20 am ] |
Yep, that's the best way. The backing plate will prevent most presses being able to remove them. Just be careful not to nick your axles |
| Author: | mudzookacoatsy [ Wed Jun 16, 2010 8:21 am ] |
ok then yeh we did a hilux one yesterday at work. oh and wat bout puting them back on ? |
| Author: | Fatzook [ Wed Jun 16, 2010 8:22 am ] |
mudzookacoatsy wrote: ok then yeh we did a hilux one yesterday at work. oh and wat bout puting them back on ?
Use a press if you can. |
| Author: | zuki [ Wed Jun 16, 2010 8:24 am ] |
mudzookacoatsy wrote: hey all,
Ive gotta replace my rear wheel bearing tomorrow at work. im wanting to know wats is the quickest way and easiest way to do it ? What didn't you believe me when I told you this arvo, thats how you get them off. |
| Author: | mudzookacoatsy [ Wed Jun 16, 2010 8:24 am ] |
umm we got one of them small work shop press not sure if it would be tall enuf but. and dont have a tube that would go over the axle |
| Author: | zuki [ Wed Jun 16, 2010 8:26 am ] |
Fatzook wrote: mudzookacoatsy wrote: ok then yeh we did a hilux one yesterday at work. oh and wat bout puting them back on ? Use a press if you can. I've used a piece of pipe to install them |
| Author: | steak_knife [ Wed Jun 16, 2010 8:27 am ] |
Fatzook wrote: mudzookacoatsy wrote: ok then yeh we did a hilux one yesterday at work. oh and wat bout puting them back on ? Use a press if you can. If not a 2 to 3 ft length of 32nb pipe, slide it over the axel & use that as a slide hammer.. |
| Author: | Fatzook [ Wed Jun 16, 2010 8:28 am ] |
mudzookacoatsy wrote: umm we got one of them small work shop press not sure if it would be tall enuf but. and dont have a tube that would go over the axle
When fitting them back on, the bearing will slip all the way to the machined shoulder at the end. Put the axle between two heavy steel plates or a bearing plate and have the end of the axle/ backing plate up in the air. Shift the bearing plates against the sides of the axle so that the bearing is onto of them, and press down on the centre of the axle. Repeat for the retainer. |
| Author: | mudzookacoatsy [ Wed Jun 16, 2010 8:28 am ] |
ok then |
| Author: | Rusho [ Wed Jun 16, 2010 10:58 am ] |
Fatzook wrote: mudzookacoatsy wrote: umm we got one of them small work shop press not sure if it would be tall enuf but. and dont have a tube that would go over the axle When fitting them back on, the bearing will slip all the way to the machined shoulder at the end. Put the axle between two heavy steel plates or a bearing plate and have the end of the axle/ backing plate up in the air. Shift the bearing plates against the sides of the axle so that the bearing is onto of them, and press down on the centre of the axle. Repeat for the retainer. And make sure you tighten the 4 little nuts on the retaining plate
| Author: | steak_knife [ Wed Jun 16, 2010 11:00 am ] |
Rusho wrote: Fatzook wrote: mudzookacoatsy wrote: umm we got one of them small work shop press not sure if it would be tall enuf but. and dont have a tube that would go over the axle When fitting them back on, the bearing will slip all the way to the machined shoulder at the end. Put the axle between two heavy steel plates or a bearing plate and have the end of the axle/ backing plate up in the air. Shift the bearing plates against the sides of the axle so that the bearing is onto of them, and press down on the centre of the axle. Repeat for the retainer. And make sure you tighten the 4 little nuts
| Author: | Fatzook [ Wed Jun 16, 2010 12:20 pm ] |
steknig wrote: Rusho wrote: Fatzook wrote: mudzookacoatsy wrote: umm we got one of them small work shop press not sure if it would be tall enuf but. and dont have a tube that would go over the axle When fitting them back on, the bearing will slip all the way to the machined shoulder at the end. Put the axle between two heavy steel plates or a bearing plate and have the end of the axle/ backing plate up in the air. Shift the bearing plates against the sides of the axle so that the bearing is onto of them, and press down on the centre of the axle. Repeat for the retainer. And make sure you tighten the 4 little nuts ![]() Yeah yeah. And your driveshaft bolts, and if your rear calipers are making heaps of noise its probably because the bolts are 3 full turns away from being finger tight .......On both sides |
| Author: | mudzookacoatsy [ Thu Jun 17, 2010 8:02 am ] |
all done thanks for all info guys. |
