| Author |
Message |
lukes_89
Joined: Fri Sep 25, 2009 11:30 pm Posts: 1204 Location: sunshine coast
 Posted: Thu Jun 17, 2010 2:05 am |
hey guys just wondering is their a difference between the 1.3 and the 1L radiators? i need a new one and a mate has a rebuilt 1L radiator he said he will sell me. will the 1L bolt straight in or should i bget a 1.3 radiator.
BUZOOKA
Joined: Sun Aug 30, 2009 11:30 pm Posts: 2659 Location: hobart tasmania
 Posted: Thu Jun 17, 2010 2:16 am |
not to highjack but i also have a question aswell.....
was told that the 1.3 nt radiator n the wt radiators were different size i was just wondering if it was tru and by how much ??
cheers buzzy
_________________ -indebt 4x4 club-
nav 32s n winch cust rear
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Thu Jun 17, 2010 3:09 am |
no, a 1.3 and a 1.3 will have the same rad size...
not sure about the 1L tho sorry.
BlueSuzy
 Posted: Thu Jun 17, 2010 3:15 am |
The wrecked 1L that i had looked very similar. Copper core etc. I know the fan is different..
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Thu Jun 17, 2010 7:22 am |
I think that the 1L is slightly smaller. will get pics of both for you tomorrow
reallyuted
Joined: Fri Nov 14, 2008 10:30 pm Posts: 253 Location: jimboomba se QLD
 Posted: Thu Jun 17, 2010 7:30 am |
1ltr is smaller and bolt holes dont line up to the 1.3
Gwagensteve
 Posted: Thu Jun 17, 2010 7:48 am |
1.0 and 1.3 are the same size. They are made slightly differently and may have a different size cap.
Interestingly, late model 660cc sierras (coily) have a larger radiator than 1.3. It's the same width but about 2.5" taller - the bottom sits lower. It bolts into 1.3 mounts.
mrw82
Joined: Tue Jul 03, 2007 11:30 pm Posts: 1350 Location: stuck in a hole. not off road, just deception bay.
 Posted: Thu Jun 17, 2010 9:37 am |
1.3 rad is about 50mm taller then a 1 litre one. mounts are slightly different but hose positions are the same.
I am running a 1.3 rad in my 1 litre and I had to drill a couple of holes and cut away a bit of the bracket then it fitted up fine. the fan shrouds won't work either, I got the 1.3 shroud but it doesn't line up with the 1 litre fan, 1 litre shroud doesn't bolt up to 1.3 rad. I didn't bother and just left it out.
Gwagensteve
 Posted: Thu Jun 17, 2010 9:40 am |
Interesting - pretty sure I've swapped freely between them on mine.
mrw82
 Posted: Thu Jun 17, 2010 10:46 am |
if you can get a hold of the brackets that bolt to the chassis then it'd definately make it a straight swap, but those bolts usually snap off before undoing.
lukes_89
 Posted: Fri Jun 18, 2010 12:00 am |
thanks guys i just went and got some steel bond putty stuff it says useful on radiators and holds up 300 degrees temp, and can be drilled and threaded so sounded decent. im going to cover up the hole with this stuff and see how i go as the hole is a the size of a needle head.
