It is currently Tue Oct 27, 2026 3:03 am
Post Posted: Thu Jun 17, 2010 7:15 am
Does anyone know where the fuses, relays etc are for the Air cond in an 88 Vitara ?? - I thought my Air Conditioning amp (black box under the glove box) was stuffed, but even after replacing it the ir cond is not firing up! - No power to the comp, (if I manually put power to it, it clicks and the the clutch engages).. I think there is a Relay for it all somewhere, but my wiring diagram doesn't show me which one it is ???
Post Posted: Thu Jun 17, 2010 7:43 am
Not sure if it applies to Vitara, but when some air conditioners have no gas in them, the compressor won't switch on, so I guess check that first. On my Sierra I recently followed the wiring from the compressor to up under the dash to find an inline fuse in there. Replaced that and everything is good again. Too bad I waited until Summer had ended to diagnose it :s
Post Posted: Thu Jun 17, 2010 9:57 am
Bridge the TX valve at the drier and see if pump engages... If it does you are low on gas.
Post Posted: Thu Jun 17, 2010 9:58 am
Oh - I have no gas in it !!! just want to see if it goes before I pay a firtune to get it regassed... apparently I may need a new dryer and some other things as it may have been gased with the old freeon ... how can you tell ?
Post Posted: Thu Jun 17, 2010 10:22 am
:? :? Pressure switch??
Kinda need gas, it lubricates the pump...
Post Posted: Thu Jun 17, 2010 10:32 am
Yes I know, but it's just one of those things I need to organise .. and want to make sure everything is going to be ok before I get it done ... apparently I'm up for about $400 ? - to convert to new gas...
Post Posted: Thu Jun 17, 2010 11:04 am
All new O'ring.s & fitting's, so sound's "about" right..
Users browsing this forum: No registered users and 222 guests
