https://auszookers.com/forum/
Air Cond - Where are things???
https://auszookers.com/forum/viewtopic.php?f=5&t=12819
Author:  ozhummer [ Thu Jun 17, 2010 7:15 am ]
Post subject:  Air Cond - Where are things???
Does anyone know where the fuses, relays etc are for the Air cond in an 88 Vitara ?? - I thought my Air Conditioning amp (black box under the glove box) was stuffed, but even after replacing it the ir cond is not firing up! - No power to the comp, (if I manually put power to it, it clicks and the the clutch engages).. I think there is a Relay for it all somewhere, but my wiring diagram doesn't show me which one it is ???
Author:  Rockhopper [ Thu Jun 17, 2010 7:43 am ]
Post subject:  Re: Air Cond - Where are things???
Not sure if it applies to Vitara, but when some air conditioners have no gas in them, the compressor won't switch on, so I guess check that first. On my Sierra I recently followed the wiring from the compressor to up under the dash to find an inline fuse in there. Replaced that and everything is good again. Too bad I waited until Summer had ended to diagnose it :s
Author:  want33s [ Thu Jun 17, 2010 9:57 am ]
Bridge the TX valve at the drier and see if pump engages... If it does you are low on gas.
Author:  ozhummer [ Thu Jun 17, 2010 9:58 am ]
Oh - I have no gas in it !!! just want to see if it goes before I pay a firtune to get it regassed... apparently I may need a new dryer and some other things as it may have been gased with the old freeon ... how can you tell ?
Author:  steak_knife [ Thu Jun 17, 2010 10:22 am ]
:? :? Pressure switch??
Kinda need gas, it lubricates the pump...
Author:  ozhummer [ Thu Jun 17, 2010 10:32 am ]
Yes I know, but it's just one of those things I need to organise .. and want to make sure everything is going to be ok before I get it done ... apparently I'm up for about $400 ? - to convert to new gas...
Author:  steak_knife [ Thu Jun 17, 2010 11:04 am ]
All new O'ring.s & fitting's, so sound's "about" right..
