| Coolant leak around Water Pump https://auszookers.com/forum/viewtopic.php?f=5&t=12847 |
| Author: | benchez [ Fri Jun 18, 2010 5:20 am ] |
| Post subject: | Coolant leak around Water Pump |
I have lost fluid in the last few days and after having a look today, noticed it leaking around the bottom of the water pump where it bolts to the block. Does this mean dead pump or just a blown gasket? Easy job or PITA? I have to change an inlet manifold gasket and do my carby gaskets in the near future, so easier to wait and do it all at once? Advice please! |
| Author: | Scrawny [ Fri Jun 18, 2010 5:25 am ] |
| Post subject: | Re: Coolant leak around Water Pump |
What engine? Leak from pump usually means dead pump. If it's a G series motor then you need to remove timing belt. All the info you need is in the download section. |
| Author: | benchez [ Fri Jun 18, 2010 10:49 am ] |
Motor is a G13. Water looks to be leaking around the bottom of the pump. |
| Author: | Rusho [ Fri Jun 18, 2010 10:56 am ] |
99% sure it will be buggered. It's a cheap fix at least |
| Author: | royce [ Fri Jun 18, 2010 11:05 am ] |
youll probably find its coming from teh drain hole in the pump once you get teh pulley off, meaning the pump is stuffed |
| Author: | Ben_Sierra [ Sat Jun 19, 2010 1:00 am ] |
I had the same thing last week... A new pump was only $50 (and I didn't really shop around). The timing belt does need to come off but still its not a massive job... |
| Author: | benchez [ Sat Jun 19, 2010 6:01 am ] |
Yeah The timing belt was easy, I did only about a week ago! If only i'd known! Oh well will just have to keep topping it up til I have my gaskets as I need to do both manifolds (exhaust needs to be changed over as it's cracked) as well as both carby mount gaskets. Some eBay shopping followed by a day under the bonnet. Awesome, it's just started getting really cold down here! |
