It is currently Mon Oct 26, 2026 9:25 pm
Vehicle: 03 Jimny
Post Posted: Fri Jun 18, 2010 6:22 am
today i went to autobarn and got some spark plugs for my suzuki sierra, but i forgot to take a sample so they had to look it up only problem was that i told them that i might have a 1.6 vatara head on my 1.3 block, im not sure as the seller said it hat a 1.6 head, so i consumed it was, so when i came home with the spark plugs which are BP5ES. i checked with the original ones and they were BP6ES, so im just wondering will they fit and wat spark plugs fit in a 1.6 head and wat will fit in a 1.3 head, as i dont have a clue wat head it is
much appreciated
Post Posted: Fri Jun 18, 2010 6:40 am
use the BP6ES plugs as they are suited better to todays shitty fuel better.
Vehicle: 03 Jimny
Post Posted: Fri Jun 18, 2010 6:46 am
dam ok, well ill have to take the spark plugs back and get the right ones
Vehicle: 03 Jimny
Post Posted: Fri Jun 18, 2010 7:06 am
what will happen if i use the BP5ES ones?
Post Posted: Fri Jun 18, 2010 7:13 am
in spark plugs the numbers are references to the temperature of the plugs,
in the NGK's the lower the number the hotter the plug..
http://www.ngksparkplugs.com/tech_suppo ... p?mode=nml
Vehicle: 03 Jimny
Post Posted: Fri Jun 18, 2010 7:20 am
well the plugs i bought are NGK BP5ES so your saying theyll run hotter then the BP6ES ones
Post Posted: Fri Jun 18, 2010 7:36 am
yeah they are hotter. i dont see it being a major problem. the plugs will probably just wear out a bit faster. you can change them if you want but if it was me i would just use them. but i am lazy.
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Vehicle: jimny
Post Posted: Fri Jun 18, 2010 8:02 am
just be aware that they are a hotter plug, dont do any extended high speed driving, if it was me i would run em, would only be a worry if it was a bp4es etc but one heat range is usually ok
Post Posted: Fri Jun 18, 2010 8:05 am
If your timing has been advanced for higher octane fuel, you may find you experience predetonation due to the spark plugs getting too hot.
Which is why many people swap to the BP6ES.
If you look at your old plugs, and they are fouled up internally, your plugs are running too cold and the BP5ES would be better suited.
Also consider tuning the carby if they are heavily fouled.
This is some useful info posted a few months ago.
I always have a good squiz at my plugs when servicing to see whats going on during combustion.
http://www.4secondsflat.com/Spark_plug_reading.html
Vehicle: 03 Jimny
Post Posted: Fri Jun 18, 2010 9:18 am
ok thanks guys, they are in ill see wat happens
Post Posted: Fri Jun 18, 2010 9:34 am
freshly rebuilt engines will have a higher compression and on todays fuel pinging is quite likely to occur. if this happends you should adjust your timing and run a cooler plug. Pinging can happen even without you knowing if things are not right inside your engine. Todays fuel is crap compared to what it was when the suzuki was built. My newly rebuilt motor has the same compression as it says in the FSMbut it pings on everything but the highest octane fuel and only with the timing set back at 4deg.
I run the BP6ES plugs. made a huge difference in my motor .
Vehicle: 03 Jimny
Post Posted: Fri Jun 18, 2010 10:19 am
i have a vitara head so thats more compression ny way then the sierra head, i need to get my timing looked at as i have pre ignition and my car runs like shit
Post Posted: Fri Jun 18, 2010 10:38 am
ummmm 1.3 is BP5es, go look under bonnets :)
1.3 in a swift is a 6, 1.6 is a 6
just fit em, youll never know the difference, shit my sierra had every combination of BP, BK, BC, BPR, BKR, BCP, in 5 6 and 7 and youd never know the difference
Vehicle: 03 Jimny
Post Posted: Fri Jun 18, 2010 10:41 am
yea the bp6es came out of it, i just end up putting the bp5es in i couldnt be bothered taking them back, got a discount ny way
Users browsing this forum: Google [Bot] and 296 guests
