| 50mm lift in front of vitara https://auszookers.com/forum/viewtopic.php?f=5&t=12876 |
| Author: | 4x4ish [ Sat Jun 19, 2010 7:45 am ] |
| Post subject: | 50mm lift in front of vitara |
ok so i have springs in the front atm that give a lift of 30mm and i have spacers (10mm) to add to get it to a 50mm lift. Car is a 93 vit. I have OME struts. Issue is that when i go to 50mm, the camber will be out and the experts seem to want to charge around the $250 mark to put in camber pins. Ive talked to a few people who say they didn't need camber adjustment. What does everyone do when they lift more than 30mm and can i get away without paying someone $250 for this wheel alignment with a couple bolts? I dont want to go adding diff spacers and all that, i just want springs and shocks. If it gets too difficult i will stay at 30mm but prefer not to. |
| Author: | royce [ Sat Jun 19, 2010 8:00 am ] |
| Post subject: | Re: 50mm lift in front of vitara |
get an alignment and see what the camber is, if its off then go to pedders and buy camber pins for $50 or less, go home and fit then get another alignment, making sure the numpty behind the till knows you have camber pins and expect them to be adjusted as part of the price |
| Author: | Joe [ Sat Jun 19, 2010 8:01 am ] |
Have a look on ebay someone said a while ago they got some camber pins for $15 a pair |
| Author: | Joe [ Sat Jun 19, 2010 8:02 am ] |
royce wrote: get an alignment and see what the camber is, if its off then go to pedders and buy camber pins for $50 or less, go home and fit then get another alignment, making sure the numpty behind the till knows you have camber pins and expect them to be adjusted as part of the price
I paid $115 |
| Author: | 4x4ish [ Sat Jun 19, 2010 8:25 am ] |
thats a good idea. I think they are over $100 from pedders thou, if anyone knows where i can get them for a decent price please let me know. I could not find any on ebay. So if i get the pins the front end will be fine to bring up, nothing else needed? |
| Author: | Bruce [ Sat Jun 19, 2010 8:27 am ] |
$100 is a decent price. Just go get them and get it fixed and all good |
| Author: | royce [ Sat Jun 19, 2010 8:27 am ] |
I paid less than $50 for mine from pedders but got trade and was a while ago, they were way cheaper than anyone else Just ring em and pretend to be some workshop and tell em youll send somebody around to pick em up |
| Author: | 4x4ish [ Sat Jun 19, 2010 8:34 am ] |
I found this video for install and adjust instructions. http://www.youtube.com/watch?v=7mYi5BupEoM and i found these pins for $82.50 delivered. http://www.4wddirect.com.au/scart/html/672.html |
| Author: | DarkHorse [ Sat Jun 19, 2010 9:03 am ] |
Will Swift ones do the job? http://cgi.ebay.com.au/Suzuki-SA-Swift- ... 335ddf4806 |
| Author: | joeblow [ Sat Jun 19, 2010 9:13 am ] |
nope, camber pins from pedders are more than 50 bucks for vits. |
| Author: | Joe [ Sat Jun 19, 2010 9:21 am ] |
4x4ish wrote:
Thats not a vitara and that guy has green hands |
| Author: | royce [ Sat Jun 19, 2010 9:24 am ] |
joeblow wrote: royce wrote: get an alignment and see what the camber is, if its off then go to pedders and buy camber pins for $50 or less, go home and fit then get another alignment, making sure the numpty behind the till knows you have camber pins and expect them to be adjusted as part of the price nope, camber pins from pedders are more than 50 bucks for vits. I must of got lucky with my $40 ones then |
| Author: | 4x4ish [ Sat Jun 19, 2010 11:56 am ] |
Here are some from uk. If i order it from overseas i can get it delivered for under $50.00 http://cgi.ebay.com.au/Suzuki-Vitara-Gr ... 335db98a64 i still see a pair of bolts being charged $100 here which is waaaaaay overpriced. Regardless of what they do at the end of the day is a pair of bolts. |
| Author: | Fluffy [ Sat Jun 19, 2010 10:26 pm ] |
i paid 100 for them from pedders last year for a vit |
