| weber setup pics? https://auszookers.com/forum/viewtopic.php?f=5&t=12935 |
| Author: | Jord [ Mon Jun 21, 2010 9:41 am ] |
| Post subject: | weber setup pics? |
hi all, second weber related thread, This time just pics of your set up, with cable mounting and other related things like vacuum line blockages and other. thought this would probably come in handy to more then one of the other people on here. as im sure others will do the same as me and buy a carb from the quokka/trading post and not have any diagrams Jordan |
| Author: | steak_knife [ Mon Jun 21, 2010 9:54 am ] |
| Post subject: | Re: weber setup pics? |
| Author: | Shansh [ Mon Jun 21, 2010 10:36 am ] |
i just used the stock throttle cable brackt with some cutting n bending & blocked off both of the vacuum lines coming to & from the stock carb, re routed the water choke hoses so they bypass the weber, goes like a rocket, looks like i fluked it first time |
| Author: | Zoook [ Mon Jun 21, 2010 10:47 am ] |
I am also thinking about getting a weber carb as my one is due for a rebuild or replacement, so while doing my research i found found this http://www.suzukiinfo.com/sierra/weber.zip The full Sierra/Vitara Weber Manual. |
| Author: | Built4thrashing [ Mon Jun 21, 2010 11:06 am ] |
Most of my webber stuff is on Outerlimits in the sierra bible. Been quite some time since i ran mine but i still have it in the shed with all the offroad mods. Just needs new throattle shaft seals. b4t |
| Author: | joeblow [ Mon Jun 21, 2010 11:31 am ] |
of all the weber systems i have played with i usually found this to be the ultimate setup.
| Author: | JrZook [ Mon Jun 21, 2010 1:09 pm ] |
joeblow wrote: of all the weber systems i have played with i usually found this to be the ultimate setup.
![]() Musn't be too good at setting them up then, ya got a funny looking tool |
| Author: | joeblow [ Mon Jun 21, 2010 9:32 pm ] |
JrZook wrote: ya got a funny looking tool
thats not what your ......... said! |
| Author: | Fatzook [ Mon Jun 21, 2010 10:10 pm ] |
joeblow wrote: JrZook wrote: ya got a massive tool thats not what your ......... said! Fixed it for ya |
| Author: | JrZook [ Tue Jun 22, 2010 2:50 am ] |
Fun-nee fella's Anyways i think my old weber setup looks alot better than JoeBlogs attempt.
Used the stock throttle cable and just bent up a bracket mounted to the carb base. Dan |
| Author: | alien [ Tue Jun 22, 2010 6:28 am ] |
there's a TON of weber info here: http://forum.outerlimits4x4.com/viewtop ... d6#p351595 i've lost my old pics unfortunately... but it was pretty much the same as above, except i ran the chrome disc thingo on top with the big round paper filter which is about 50mm tall all up. Biggest problem with this setup is water in the engine bay, and any dust/mud clogs the filter really fast. |
| Author: | steak_knife [ Tue Jun 22, 2010 6:28 am ] |
JrZook wrote: ![]() Used the stock throttle cable and just bent up a bracket mounted to the carb base. Dan Why do you have a brake line g/clamp in your eng bay & how the does accelerator feel with the cable at the angle?? |
| Author: | xaravitara [ Tue Jun 22, 2010 7:01 am ] |
Zoook wrote: I am also thinking about getting a weber carb as my one is due for a rebuild or replacement, so while doing my research i found found this
http://www.suzukiinfo.com/sierra/weber.zip The full Sierra/Vitara Weber Manual. Yatzee! Your name will amongst the great ones. Einstein, Galileo, Armstrong, Billy the Kid, Santa, and Zoook! Been to this site before but never looked under the sierra section. Wish I had this when I first bought my Weber! Cheers for the link! |
| Author: | JrZook [ Tue Jun 22, 2010 9:04 am ] |
steknig wrote: Why do you have a brake line g/clamp in your eng bay & how the does accelerator feel with the cable at the angle??
That was initial install, bent the bracket the straighten the cable a bit more than whats shown there. No issues on the cable, on the weber throttle movement was sooo much lighter and easier. Clamping off fuel line in the pic, think i was draining the bowl. Dan |
| Author: | Built4thrashing [ Tue Jun 22, 2010 1:04 pm ] |
ps of weber stuff in here. http://www.outerlimits4x4.com/viewtopic.php?t=28919. long read but explains alot of issues people have. B4T |
| Author: | steak_knife [ Tue Jun 22, 2010 8:39 pm ] |
JrZook wrote: steknig wrote: Why do you have a brake line g/clamp in your eng bay & how the does accelerator feel with the cable at the angle?? That was initial install, bent the bracket the straighten the cable a bit more than whats shown there. No issues on the cable, on the weber throttle movement was sooo much lighter and easier. Clamping off fuel line in the pic, think i was draining the bowl. Dan Cheer's.. |
